Question about Standard (CRT) Televisions
RCA Guide plus gemstar T.V.
When I plug the T.V into the wall it makes a high pitch noise with a blank gray screen.
    Problem Solver:
  • 7 Answers
Re: RCA Guide plus gemstar T.V.
So the tv screen is on after the noise? Does it end up shutting off?
Posted on Nov 24, 2007
0 characters
3 Points
Why does my rca guide plus gold gemstar tv have lines or bars flickering on the screen ?
are they horizontal or diagonal? if they are diagonal it could be you're brightness is turned up too high. try turning it down.
Aug 13, 2012 | RCA F36705 36" TV
I have a RCA guide plus gemstar t.v.I have lost the set up the guide plus in a new area I need to change the zip code.Its a 2003 model 36F53OT.where can I order one or an alternative solution.
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
Sep 17, 2011 | RCA 36F530T 36" TV
Volume broke
yes. unplug. wait 2 minutes, plug back in. turn on. with factory remote control for tv, 7, 1, go-back, tv....... easy
Nov 13, 2009 | RCA Standard (CRT) Televisions
Our Guide Plus shows no listings. We have gone
This is For Guide Plus that comes with ATI TV Tuners
I got this in an e-mail from Macrovision and IT WORKS!!!
I deleted the files they said, and got a new error message, so I reinstalled Guide plus, left out that step, and GUIDE PLUS IS BACK!!
Please try belows instructions to see if that helps. Please back up any data and registry before going forward. We take no responsibility for any wrong doing. Please follow instructions carefully.
1. Delete all files in these directories:
C:\Program Files\Gemstar\GUIDE PLUS+(TM)\ATI\download
C:\Program Files\Gemstar\GUIDE PLUS+(TM)\ATI\panelad
2. Go to the computer's registry:
Find the strings:
Change string "1" to
string "2" can be left alone
string "URL" SHOULD be
Aug 18, 2009 | RCA Standard (CRT) Televisions
My RCA TV went blank and has a high pitch noise.
it's probably not the tube. Sounds like something is shorting the B+ from the power supply. Could be the Horizontal Output transistor or the Flyback transformer. Do you know how to find these components? I could be a rectifier diode on the secondary of the power supply as well. If you know what you're doing check those with a meter. If you don't know what you're doing, ask someone who does.
Good Luck.
Jul 22, 2009 | Sanyo DS31520 31" TV
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
Loud sound, No TV Picture
Power supply needs to be replaced - common problem with these tv"s
Sep 18, 2008 | RCA 32F531T 32" TV
Standard (CRT) Televisions Logo
238 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
