SOURCE: Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
SOURCE: Speaker phone volume keeps going loud and quiet
Did the location change, a Echo from a wall or vibration from the table. It is a one way sound, someone talks and you hear. As soon as you talk it cuts out the speaker even if they are still talking and it transmitts what you say. So any noise in the room could trigger the the transmit mode even an echo from the sound being turned up too loud. The mike is on the bottom of the base and can pick up table vibration and send it into transmit mode. So the person talking cuts in and out.
AL
SOURCE: Unable to reset lamp life notification
Try it, press and hold Volume Down on TV front and 0 (zero) button on Remote at same time for 5~6 seconds to reset lamp timer.
Thanks.
Testimonial: "Great advice...the key was using the front panel of the TV for the volume button with the Play/PP button. Thank you! Steve "
SOURCE: How do I turn the ringer volume down on my Samsung
Hi, to change the ringer volume on your Samsung DCS - with the handset down, press TRANSFER 114, then hit 1 to 8 on your keypad - (1 being the quietest setting) please look at the video I've posted for you, If you find this useful checkout YouTube search 'abbeytel' where you will find over 60 more 'how to videos' relating to the Samsung DCS
SOURCE: i have a parrot ck3000,
You will need to plug in the original parrot control to do this. contact the supplier if you do not have it as they should have left it with you. Otherwise Parrot web site has a list of certified engineers.
