Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load. Started a load ran fine, then sat with one minute left on timer. Waited........nothing. Unplugged unit, manually unlocked door, removed load. Started over goes on all options respond press start beep and nothing goes
  • 4 more comments
  • mdstmartin Jul 31, 2009
    this is a fron load washer
    I have held the button, it made no difference. the model is110. 4753
    I have held the button and no change. model110.4751
    I Have a front load washing machine,model 110.4751. It stop with one minute left on the cyle. I left it for a while tried repressing start, but to no avail. I unplugged it and found out how to manually open the door as it stayed locked after I plugged it back in. Everything response "normally" when I set it to wash, but I press start and it does nothing.
    I have a kenmore front load washer HE 2Plus model 110.4751. It runs through a cycle but stops with one minute left on spin.
    Ok, so where is the CCU and is it hard to replace?
  • 6,784 Answers
HI, the main logic sector of the CCU(Central Control Unit), is malfunctioning at this time. this sector is responsible for initiating the entire wash cycle. Normally, when you have an interruption of this nature, it will be a strong indicator of logic chip set failure in the CCU. The CCU is basically the main control board and, i recommend to replace this CCU asap, if possible This will correct your problem.
NOTE**
(((Some logic faults can be reset by just unplugging the unit or cutting power to the unit for 5 minutes. This may reset the chip set on the CCU, and restore normal functions. If not done already, try to reset the CCU by unplugging for 5 minutes. If this continues after the reset, replace the CCU asap))).
Posted on Jul 31, 2009
  • Michael Masters
    Michael Masters Jul 31, 2009
    This is one of the hardest repairs to accomplish on this model. it is located inside the unit, mounted on the inside wall next to the drum. It will be on the same side of the unit as the main interface is located. This will require some of the cabinets parts to be disassembled, and the drum may need to be removed in some cases, depending on how the wiring harness is installed. Its quite tedious, and we recommend a qualified service tech for this type of electrical repair.
  • 10,865 Answers
Hello. There are several possible reasons why you are having this problem. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
It could also be the timer itself. Unfortunately there is no quick and easy owner repair. Most likely you will need to call sears. It may be under warranty. Good luck.
    President:
  • 1,723 Answers
Is this a washer or dryer? Do you have the manual? I think this is a gas dryer from the research I did on HE2 is that right?
  • 1 more comment
  • Craig Butler
    Craig Butler Jul 31, 2009
    I found a manual that is close and it said to try this
    Large loads may require pressing and holding the Start
    button for 2-5 seconds.
  • Craig Butler
    Did you try holding the start button for 5 seconds?
  • Craig Butler
    Do you have a model number ?
Door will not unlock after being unplugged and plugged backnin
Hello Tina,
You have to press & hold the "Drain & Spin" button for 3 seconds in order to unlock the door, assuming that the tub is not full of water, otherwise the system will attempt to drain it first before unlocking the door.
Good Luck!
Rich Lilja
Apr 16, 2016 | Kenmore HE2 Plus Front Load Washer
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
My washer is on lock and add clothes...can't get it to open...what do I do? I have clothes in it, and the timer says 54 minutes left.
Manual Door Unlocking Procedure
  1. Disconnect power and lean the washer on its back against the wall. You can prop up the bottom front edge.
  2. Remove the lower toe panel by removing the three screws under the bottom edge on the front of the washer.
  3. Reach up along the inside of the right side of the front panel and locate the tear-drop shaped tab and gently pull it down until a click is heard.
  4. You can now open the door.
Oct 29, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore HE2 Plus Front Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
