Question about IBM Lexmark Z715 InkJet Printer
Status Box Remains at 99%
Completes a printing job. Ejects perfectly printed page. Always shows 99% never 100% complete on print status box. Consequently the print icon remains on the lower tool bar and the printer will not accept another request.
    Problem Solver:
  • 7 Answers
Re: Status Box Remains at 99%
Try uninstalling then re-installing the drivers. Also if you are using Windows Vista you may need to go to the printer manufacturers website and download Vista drivers if you are running XP drivers for the printer.
Posted on Nov 24, 2007
0 characters
3 Points
I replaced the cartridge of my hp psc 1401, copied the test page that was automatically printed, but now I can't print anything. Copying works OK. I don't get an error message or blinking lights on...
what is the status of print job in the queue? whether it is showing printing or no status in the windows.
if the status is printing you delete all the print jobs and switch off and on .then try print something. if no status is there in the windows then you check whether the printer is off line .try make it online by right click on the printer icon then click on the use printer online.
Aug 10, 2011 | HP PSC 1401 All-In-One Printer
My HP Laserjet 2840 is showing "replace supplies" in the display. There are 5 box/cylendar's that appear in the display and the last one has a solid black box box in it. I was able to go thru...
Thank you for contacting FixYa with your printer inquiry.
The low ink could definitely be the problem thats prompting the error. To begin troubleshooting print the supply status page and confirm the state of the various supplies. Follow the steps below:
Supplies Status page The Supplies Status page lists the remaining life of the HP print cartridges and the HP imaging drums. It also lists the estimated pages remaining, number of pages printed, and other supplies information. You can print a Supplies Status page from the device or the HP Toolbox. To print from the device, complete the following steps. 1. On the control panel menu, press MENU. 2. Use the button to select Reports, and then press ENTER 3. Use the button to select Supplies Status, and then press ENTER. Note Supplies information is also available through the HP Toolbox.
This page illustrates conditions of consumables for Toner Cartridges, Image Drums, Image Transfer Kits, and Fuser Kits. It also provides ordering information and methods for disposing of or recycling used supplies.
Areas of Supply Status Page: 1. Print-cartridge area. This area contains a section for each of the print cartridges and provides information about HP print cartridges. This information includes the part number for each print cartridge, whether each print cartridge is low, and the life remaining for each print cartridge expressed as a percentage, as a graphic, and as the estimated number of pages remaining. This information might not be provided for non- HP supplies. In some cases, if a non-HP supply is installed, an alert message appears instead. 2. Imaging-drum area. This area contains the same information for the imaging drum that the print-cartridge area provides for the print cartridges. 3. Warranty Note. This section contains information about how the device warranty is affected when you use non-HP supplies. It also requests that you call the HP fraud hotline if a supply that is being detected as a non-HP supply was sold to you as a genuine HP supply. (See HP fraud hotline.) 4. Ordering Information. This section contains basic information about how to order new HP supplies. See Checking status and ordering supplies. 5. Recycling Information. This section contains a link to the website that you can visit for information about recycling. See Replacing and recycling supplies.
The product Support Manual is available from the below link:
If you have further questions just add comment to this link and we will gladly provide additional information and support.
Kind regards,
Jun 08, 2011 | HP LaserJet 2840 Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
How can I get a printout of the number of copies printed on my 1320?
Suggest the following as you are not able to connect through the tool box
a. press Go (the green button) for five seconds when the printer is in the ready state.
this will print the configuration page and then the supplies status page for the current toner in the printer.
The Supplies Status page provides information about the print cartridge that is installed in the printer, the amount of toner left in the print cartridge, and the number of pages and print jobs that have been processed. The Supplies Status page automatically prints when a Configuration page is printed from the control panel.
hope that helps
Sep 25, 2009 | HP LaserJet 1320 Printer
Double printing on single jobs.
You have software setting problem Check and double check your print dialogue box
Apr 21, 2009 | HP LaserJet 4350 Printer
Printer is a Canon MP470 all-in-one, USB connected. OS is Windows XP. Latest printer drivers are installed. After print job completes, status of print job remains in print spool as "printing". If I cancel...
Is your printer hooked up to your network?
Make sure all your settings are correct and try connecting the printer directly into your computer. Then print if it does not work still then comment back and I will be glad to help.
Hope this helped.
-Please rate if this helped
Feb 19, 2009 | Epson LQ-590 Matrix Printer
Print document w deleting status in que is frozen
This happens periodically, for me restarting the machine has always fixed the issue. If it didn't for you I would suggest removing and reinstalling the printer.
Dec 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
IBM Lexmark Z715 InkJet Printer Logo
132 people viewed this question
Top IBM Printers & Copiers Experts
Level 1 Expert
Are you an IBM Printer and Copier Expert? Answer questions, earn points and help others
