First, I'm not a Vissani tech.
*Check your warranty and call for service.
*** Following is for information only.***
* I see that you have done most of the following. I'll post the full answer for others to review. You probably need a complete defrost and return the settings to the middle.
*** Complete answer as follows ***
* Check for air movement while fan is running. Many have plastic ducting that pulls air from the bottom that is usually covered by the lower drawer. Pull out the lowest tray and check the back for ice or food that fell in back to block the air vent. If it's iced up, DON'T hit it as you will crack the plastic. Leave the door open, Turn off and let the freezer defrost. (remove food).
* Check the upper fan vent for ice blockage. Defrost as needed.
* Unplug refrigerator to defrost. (Get help to move as the fridge is heavy and may tip over on you.)
* Once completely free of ice (it takes a while. A fan blowing into the freezer helps. ***DONOT use a heater!*** Warps panels and may over pressurize refrigerant.)
* Allow a completed defrosting of the freezer. (Place frozen foods in refrigerator side to keep it cold while the refrigerator is off. Better to transfer everything to another refrigerator.)
* Keep checking and dumping the drain tray as the ice melts. If no water drains then the line may be clogged. Call for service.?
* Plug in refrigerator but leave out where you still can unplug it if you need to continue to defrost. Move it back only if everything is working (so far).
* Set the temperature to middle of dial and the freezer diverter to normal (middle). Leave fridge empty to allow it to cool down without a load. Check for icing (there shouldn't be any as there is no moisture in box to ice up.) If there is ice then it did not defrost enough. Turn off and repeat manual defrost (open door)
* Once your sure all the ice is gone and the freezer is cold. Move refrigerator back into the counter/wall. (it's lighter but get help anyway.) Start putting back the frozen goods. Try not to cram in everything. Keep enough space on racks to allow air flow AROUND the whole shelf. Keep away from leaning food against the walls and back.
* Leave the temperature setting at mid range. Your refrigerator should be able to keep food frozen at this setting.
* Check your door seals for cracks
* Check your door perimeter for warmth. It should not be sweating or ice cold. Cool or slightly warm to the touch is normal.
* Check your side panels (not doors). It should be cool but not iced or sweating.
* Final, with the Temperature set at mid range. If your still getting ice then you have a vapor leak. (Moist air getting into the freezer) Note that this moisture can also come from hot moist food placed in freezer without pre-chilling it. If you must put hot food In the freezer. Then place it in the refrigerator section for at least an hour prior to the freezer. The refrigerator can handle the moisture load better than the freezer. The refrigerator just collects the water and drains it to the bottom pan.
* Again, check your warranty and call for service. Have them perform yearly maintenance to check everything.
Aloha, ukeboy57
PS; If everything is okay (so far) then only gradually adjust the temperature SLOWLY. You will find that maxing to the coldest setting will only build up the ice quicker. Normal freezer operation can take care of the occasional (daily) opening of the freezer door. It will 'dry' out the frost and ice build up (If given the chance). But if you find that Ice keeps building then you need a bigger new ice box.
SOURCE: Fridge not cooling compressor works intermitently
Is the brand name of the compressor Tecumseh?? How old is this fridge??
SOURCE: I've got an electrolux frost
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over
ice will get collected on freezer ventilations and that will block the
air passing section from freezer to fridge, so the freezer gets cool but fridge
section does not cool.Its defrost problem. Try
manual defrost by unplugging the refrigerator from main power outlet
for 24 hours then reconnect it and check, if the same problem is noticed again,.
If yes then its defrost board problem. The defrost board located in the back of
fridge section. You can get required parts from www.repairclinic.com or from
online sears part site. ------------- Thank you.
