Question about Frigidaire FEQ332E Electric Dryer
Stacking Instructions Hi, I want to stack my Frigidaire Dryer (FEQ332CESO) onto my Frigidaire Washer (FTF530FS1). I understand that I need to remove the lid from the washer. I don't see any brackets on the dryer. I see the legs on the bottom of the dryer. Do they need to be removed? Any help would be greatly appreciated. Thanks, Marianne
  • Swany123 Mar 30, 2008
    i just purchased a "stackable" front load Frigidaire washer and dryer. I was also sold the "stacking kit". However I could not figure out how to attach the back stacking kit brackets. I called Vann's (where I purchased it) and they said something about removing the top of the washer. I did that and still do not see how to stack it! Nothing in the manuals says, either! HELP!
  • Anonymous Aug 07, 2008
    WE have Frigidaire GLGQ332 dryer and GLTF167 washer, would like to stack and cannot find instructions...removed top and cannot figure out. I thought it could be done without stacking kit...
  • 447 Answers
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Posted on Nov 24, 2007
Hello Marianne  i don t know if you ve found the answer on how to stack the washer and dryer but here it go, i was looking for that as well on the net and no such instruction, i had the print instructions that i found  hope it ll be helpfull
Posted on Jan 01, 2008
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
How to stack dryer LEQ1442ES1 and what stack kit to buy?
Hello Friend, that's a great question!
The recommended stacking kit for your Frigidaire dryer (LEQ1442ES1) is part number STACKIT2. Further information regarding the stacking kit and directions can be found in the installation instructions listed below. Hope this helps! - Z
Frigidaire Manual Search Results
Sep 05, 2014 | Frigidaire Dryers
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
Stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Dec 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FEQ332E Electric Dryer Logo
2,935 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
