Question about Timex Watches
How do you take the back off a watch?
Timex watch to change battery
    Top Expert:
  • Timex Master
  • 49,110 Answers
The easiest way it to take your Timex watch to a jeweler who will demonstrate how to remove the back and may be persuaded to install a replacement battery - all for a reasonable sum.
Posted on Feb 21, 2018
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
SOURCE: changing the battery
You need to pry it open.
I used an X-acto knife
Posted on Jan 08, 2008
SOURCE: How do I release the
I just had this problem, and my 8 year old and I had to fiddle a bit to figure it out.
Just to confirm, you have removed the back cover and taken the watch guts out of the face and strap assembly and are looking at the battery which has a cover over it and maybe a sticker on the cover that says "unlatch to remove battery", with two >'s, one pointing to to each side?
On each side there are two small metal tabs, which surround a small moulded-in plastic piece with an opening in the middle.
The release is in that opening in the plastic piece. You need to fish around in that opening a little to catch the release and push it outward toward the edge of the watch (away from the battery). You need something very small to do this with, like a straight pin. If successful, the cover pops up on one side and then you do the same on the other side.
Good luck.
Posted on Jul 21, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
  • 110 Answers
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Posted on Dec 06, 2009
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
I have a Timex Ironman 30-Lap Mid watch with a dead battery. I purchased a CR 2016 battery as stated on the back cover of the watch. How do I change the battery?
This one is quite simple. Just remove the watch back with a watch case knife and flick out the old cell then carefully press in the new one (VERY carefully as the movement is made of plastic). fit the back exactly the way it came off (note the direction of the writing).
Sep 19, 2010 | Timex Watches
I have a timex watch with both analogue and digital.... only the digital is working after a battery change. What do you recommend
Take the battery out again and let the watch "rest" for a couple of hours without the battery. That sometimes resets the Quartz mechanism, and will allow a clean restart. Also, refer to the following info if needed.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 05, 2010 | Timex Watches
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Feb 01, 2010 | Timex Expedition Camouflage 40691 Wrist...
Timex Ironman 30 lap heart rate does not display
the battery type is written on the back of the watch.
Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
Apr 08, 2009 | Timex T41091 Expedition Watch
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Watches Logo
389 people viewed this question
Top Timex Watches Experts
freddyfox
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
