Question about Hoover Vacuums
Hoover windtunnel pro pet 3 hard to push or pull
  • Hoover Master
  • 1,571 Answers
Start by replacing the belt and cleaning the bottom
Posted on Feb 25, 2018
reddevil6
  • 1673 Answers
SOURCE: hoover upright windtunnel isnt propelling itself anymore
If the V belt is loose with the handle down, then maybe the idler wheel under neath the belt isn't contacting the belt, may be jammed down, just push on it to see if it moves up and down. Belts don't last very long, you may want to replace both of them.
Posted on Feb 14, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 18 Answers
SOURCE: hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Posted on Oct 08, 2009
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
I took the filter out of my Windtnnel Pro Pet to clean it (not with water) I put it back in and now the vacuum wont turn on.
I'm going to guess that when you put it back together it didn't quite go back in correctly. There could be a switch that prevents it from turning on if the filter is not installed. Make sure that it is seated correctly. I hope thats all it is.
Dec 27, 2014 | Tti Hoover 4010100Y 3-Pack Type Y...
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 31, 2013 | Hoover WindTunnel Purely Pet Vacuum...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Just purchased the windtunnel T series pet version...I cannot turn the carpet height adjustment knob to save my life. Is it locked somehow? or is there a way to get it moving?
with the vacuum in the upright position push the handle foward then reach foward and slide the lever to the proper position that also works to ingauge the power drive or to release the handle thanks hope this helps Don the Vacuum Doctor Alb N.M.
Nov 01, 2009 | Hoover U5753-900 WindTunnel Bagless...
I purchased a hoover windtunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=724091
Generic problem for all Vacuums
I purchased a Hoover WindTunnel
Posted by billmar082 on Jun 30, 2008
I purchased a Hoover WindTunnel 2 model#u8361900 in Dec 2007.I am very disappointed because the self cleaning filter is not turning and particles keep clogging in that area. I have manually removed the particles but the filter will not turn. I also haven't been able to use the pet brush for some time. The cleaner has not been used hard about once a week since it was purchased. I am not happy that this product has stopped working efficiently since purchased 6 months ago. Thank you Marcia Long Pottstown Pa
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I sorry you are having a problem with the Hoover WindTunnel Vacuum Model #U8361-900 but I never heard of a filter that you say is self cleaning and NOT turning. I have never seen a filter that turns inside the chamber, the dust and dirt basically go around and circulate around the filter and you can clean the filter by either brushing it off, vacuuming it off or using some type of brush to clean off the filter such as and old paint brush or if you have some type of blower system – that would work as well. You said your vacuum is less than one year old so I would contact your local factory authorized Hoover dealer in your area or to cal the cust serv @ the Hoover factory listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
Vacuums Logo
257 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
