Question about Mitsubishi Televison & Video
I have an older Mitsubishi V.S.-45605 when the power button is pushed the green light blinks for a second but the TV does not come on
  • kenny30378 Jul 31, 2009
    Thank you for your help but I live on an island in southeast alaska and there is no local tv repairman. I am pretty mechanially inclined is there any way you could talk me through this? what part will I need?
    President:
  • 2,777 Answers
This is an indicator that you have an internal power supply failure. If you get no picture at all this is almost certainly the case. Try unplugging it for 2 minutes and plugging it back in. If this does not restore power you will need to call a local TV repair shop and have them verify that the power supply has failed. Luckily this is the least expensive repair out there, so you shouldn't be out all that much.
Thanks
Tim
Posted on Jul 31, 2009
  • Tim Grayson
    Tim Grayson Jul 31, 2009
    Oh dear, well this is a good place to get it from since it has a good return policy in case it isn't the part, which a TV place could verify. I have two parts to recommend, it's probably going to be:
    http://www.partstore.com/Part/Mitsubishi...
    But if that is not it then it could be:
    They should include installation instructions, once you get the back of the TV off and have the part in hand it is fairly obvious how it gets installed.
    Thanks
    Tim
Mitsubishi WD-48511 Flashing green power light
The green light should only blink if set has been unplugged---upon plugging it back it will blink for about 70 seconds and go out----this is the set booting up and is normal.
At that point you should be able to turn the set on-----what happens when you try?
Mar 17, 2012 | Mitsubishi WD Televison & Video
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
Mitsubishi VS-45605 rear projection tv
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Jul 13, 2007 | Mitsubishi VS-45605 50" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
When I turn on the tv I see the green light power come on and then it will just shut off right away
Depending on actual model number most of these sets have a self check.
When green light goes out: On front of set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat several times.
Let me know what error code you find and comment here and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Oct 05, 2010 | Mitsubishi Televison & Video
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Try pushing Input and Menu together and hold them both in for 5 seconds to see if it blinks a 2 digit code which repeats itself. Then let me know what it does and we can go from there.
Jan 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
HDTV 1080
IF your Mits model # is WS-xxx13 type, then the DM module
is at fault.....requires replacement of four 1000mf 25V 105
degree capacitors.........for more info......go to.......
www.chrisandnat.com/projects/blinkingtv/blink.htm .............T.
Dec 18, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
