Question about Kenmore 75088 Air Conditioner
Programming my Kenmore AC's sleep mode and timer
I don't have the manual for my Kenmore AC (I think it's the 75088 - the number on it is 2537508830), and I don't know how to program sleep mode or the timer. I've been trial and error-ing it and not getting very far. Any assistance would be greatly appreciated!
5 Suggested Answers
SOURCE: Looking for a ''FREE'' owners manual download Kenmore 385 17124
kenmore 158.132.01 manual
Posted on Aug 12, 2009
mgprice
  • 744 Answers
SOURCE: i have a kenmore side by side refrigerator. the
Hi, Is there ice/frost build up at the rear inside of the freezer?. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
4462625.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
f218caf.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
a4183d8.png Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Posted on Nov 20, 2009
  • 99 Answers
SOURCE: Kenmore~digital~12 cup~Coffee Maker ~
check online most operator manuals are available for free download (saves sears a ton of calls)
Posted on Apr 18, 2011
aaahandy
  • 186 Answers
SOURCE: Need too know where is the timer located on my Kenmore refrigerator model number 596.66952401
I don't believe it has one, it operates off the controll board. Sorry to ask but what is the main problem with this unit?
Posted on Mar 08, 2016
I borrowed a portable a/c unit Comfort -Aire model number PD121-5 cant get it 2 stay on cool it has timer & changes temp all the time. can anyone tell me how to reset this thing? No remote
some ac units portable or other wise use a program where it starts on full cool and as the humidity is removed from the room the program changes to less cool or switches off for periods ( called comfort mode on some units and is used for sleeping where the room temp is maintained and does't get colder as the night goes on)
try and down load a operators manual from the net
Jun 29, 2015 | Heating & Cooling
How do i keep the wifi on my epson wf2540 printer from going to sleep
  1. The Sleep Timer
    The product enters sleep mode if it is not used for a period of time. You can adjust the time period before sleep mode, but increasing the time reduces the product's energy efficiency.
    Changing the Sleep Timer Setting From the Control Panel Changing the Sleep Timer Setting - Windows
    Changing the Sleep Timer Setting - Mac OS X
    Parent topic: Product Basics
    You can use the product's control panel to change the time period before the product enters sleep mode.
    1. Press the [img src="file:///page23image5084" alt="page23image5084" width="15.095703" height="9.057693">button.
    2. Press the up or down arrow buttons to select Printer Setup and press the OK button. You see this screen:
& check the manual page 23 https://files.support.epson.com/pdf/wf2540/wf2540ug.pdf#page23
Sep 05, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
I have a Gardena water timer T1030 D rthat starts at the right time but don't close even not in manual on/off. What is wrong and how to solve it?
Reset timer to clear programs, and try programing again.
Copy following link for Gardena timer manuals
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 14, 2012 | GARDENA Water Timer
Kenmore 70121 air conditioner
There should be a sleep mode button on the remote. Press this then pres ok/enter.
Note: In this "MODE" the selected temperature will increase by 2 degrees F 30 minutes after the mode is selected. The temperature will then increase by another 2 degrees F after an additional 30 minutes. This new temperature will be maintained for 7 hours before it returns to the originally selected temperature. This ends the "Sleep" MODE and the unit will continue to operate as originally programmed. The "Sleep" MODE program can be canceled at any time during operation by pressing; Sleep MODE, "On/Off", "Fan Only" or the "V//X" buttons, on either the Control or the Remote. "Time Delay Stop" limit reached will also end "sleep" MODE.
Jun 01, 2012 | Kenmore Heating & Cooling
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Kenmore 75088 Air Conditioner Logo
222 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
