Question about OKI C9300 Led Printer
Transfer belt for the oki 9300 led printer
Transfer belt ( one message say it has 98 % life remaining) ( while the message says install new belt)
    Problem Solver:
  • 5 Answers
Swith off the machine before installing new units. Also check for toner dust on pins and also check to see if the pins are not bent. You can also try leaving the machine switched off for about an hour unplugged from the mains.
Posted on Jun 26, 2008
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
What does a "K Drum Life" warning mean?
Meaning the life of the k drum is near and you need to replaced it soon or later
other message like below need attention
ecblank.gif C DRUM LIFE REMAINING nn% ecblank.gif M DRUM LIFE REMAINING nn% ecblank.gif Y DRUM LIFE REMAINING nn% ecblank.gif BELT LIFE REMAINING nn% ecblank.gif FUSER LIFE REMAINING nn% ecblank.gif K TONER REMAINING nn% ecblank.gif C TONER REMAINING nn% ecblank.gif M TONER REMAINING nn% ecblank.gif Y TONER REMAINING nn%
May 31, 2011 | OKI C3200n Led Printer
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
My oki transfer belt is saying that it has run its course despite it has just been installed ( new)
The waste toner bottle is on the underside of the transfere belt. Becareful when you unclip as it can break. Another option is to drill a small hole on the back to empty the toner and then seal it up again. You do this at your own risk so becareful!
Nov 24, 2007 | OKI C9300 Led Printer
OKI C9300 Led Printer Logo
271 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
