THE GAME OR BLUE RAY MOVIE WILL LOAD AND PLAY BUT WILL FREEZE MINUTES AFTER STARTING.
Try doing a factory reset but be warned resetting it deletes all data and restores it back to factory default this should correct the software glich that is causing your ps3 to freez or lock up
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset
