Question about Honeywell Heating & Cooling
How to hook up Honeywell rth 7600. have an extra wire
Ooking up a Honeywell rth7600 to a heat pump.
old wires (from ancient mercury tstat)
b= brown,
w2= white ,
o= orange,
x= blue,
r=red ,
e= blk and ialways seem to end up with an extra wire.
assuming that o,r,y and g arematching ....
b is then supposed to go to c.
aux = w2 (white),
e = e,
c = x orb
and i end up with both. ?? the manual then says to STOP EVERYthing and call a local contractor. ??
  • Thomas Woodburn
    Thomas Woodburn May 13, 2017
    Sorry, I found it. Brown was your common it should go to c. White and Blue will go to aux. The blue is the signal from the heat pump that it is in defrost. White goes to the actual heat strips. These should go together.
  • 1,657 Answers
From what I'm seeing the 7600 is not compatible with a heat pump. Where are you landing the orange wire?
Posted on May 12, 2017
  • 540 Answers
SOURCE: i have a honeywell focus
W== heat which we'll call this w-1! w2== second stage!
Posted on Sep 04, 2008
SOURCE: Hunter 44100A programmable thermostat
Sorry Iasumed you had a heat pump t-stat. You will need to exchange to a heat pump t-stat
Posted on Sep 28, 2008
  • 85 Answers
SOURCE: i am replacing a white
Blue (C) or sometimes (B) should be your common wire. Look at your schematics and locate common. Your Brown wire is (E) and is emergency heat, white wire (W) is Auxilary Heat, green wire (G) is fan relay, red wire (R) is power, yellow wire (Y) is Cooling and orange wire (O) is reversing valve.
Posted on Dec 02, 2008
  • 38 Answers
SOURCE: i need a wire diagram of a central heat and air with a heat pump
W- White (heat)
Y- Yellow (condenser)
G- Green (Indoor fan)
C- Blue (Common 24v)
R- Red (24VAC)
O/B (Only needed if system is a heat pump)
Posted on May 07, 2009
SOURCE: Trane Weathertron XE1000 Thermostat Wiring
my weathertron heat pump stopped putting out heat
Posted on Jan 13, 2010
Replacing Thermostat I'm replacing our current battery-operated Honeywell thermostat with a wifi Honeywell thermostat. Our current one does not have a c wire hooked up to it but it does have two unused...
The c in the furnace that is white is going to your condenser, it must stay. ADD the blue that goes to the tstat OR brown, which ever and then use that color on your new tstat and you will be fine. Always turn power off when changing stat
Sep 26, 2017 | Honeywell Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Old wiring looks like this yellow =y1 green =G white=w2 orange =O blue=C red=R installing a Honeywell RTH7600 where does the orange wire go we have a heatpump.L
If you have a heat pump, the thermostat that will operate it most generally will have an "O' terminal for the orange wire, this is the circuit that energizes the reversing valve on the heat pump, be sure that the stat says heat pump on the box. hope this helps
Nov 02, 2009 | Honeywell Electronic Programmable...
Trying to replace honeywell T8001C thermostat with new honeywell RTH7600. The old had a brown not used & a blue. On the new unit not sure where they go. Hooked it up with red,yellow,white,green &...
Red is usually hot side of transformer,yellow is for the a/c compressor,white is for heater,green is for the blower fan,now the blue could be energize for heat or the common side for the transformer,brown can also be the common side of the transformer. It sounds like you need the blue wire connected to the common side for the thermostat....but be careful. Some units use this as a energize wire and are not a common. I would find out what furnace model you have then look online and double check what this wire is or you could damage the new thermostat and/or the 24 volt system on your fau. And also always have the power to the unit disconnected so you do not ground a circuit.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Hooking up new thermostat to new furnace
Letter designations for honeywell tsats R=24 volt power, W=heat, Y=cooling, G=fan, C=common wire for the 24volt power to tstat. Generally R is the red tstat wire and so on. Blue tstat wire can be hooked up to common at the tstat. On the heater the blue tstat wire would be hooked up to the C terminal. But this also depends on the manufacturer of heating unit.
Jan 22, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,255 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
