Question about Marantz PM-15S1 2-Channel Amplifier
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
  • 979 Answers
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Posted on Jul 31, 2009
I bought a 3.15A/250V- 220 V for my servo 240 and it keeps on blowin everytime i put on a new one.
Fuses blow when there's an overload. Nine times out of ten this is caused by a short-circuited device on the heatsink.
Jul 10, 2014 | Samson Audio Players & Recorders
Marantz amplifier PM68 replace fuse
You don't see any glass fuses? There is also a non replaceable fuse in the power transformer.
Apr 06, 2014 | Marantz PM-68 Amplifier
Marantz PM4001
The converter should not b e a problem. It's time to ask a technician or a HiFi shop, an internal short circuit is blowing the fuse. Don't insist.
Feb 05, 2014 | Marantz Audio Players & Recorders
I have a Marantz PM 55SE amplifier. The fuse kept blowing but i managed to fix this by putting in a slightly bigger one. However the left channel keeps going from ok to distorted to off. Any ideas what...
First it's very dangerous to put a larger fuse in any device than the stated rated. Fuses blow when there's an overload, that could cause a fire! Fortunately (for you) it has shown you that the left power amp is the faulty device that was causing the correct rated fuse to blow in the first place. If you have a Ohm meter you can put the leads on the terminals of the transistors in left channel and you should find one or more that acts like you have touched the tests probes together! If there are two transistors in the left channel I advise you to replace both, even if one seems OK. Also look around for burnt resistors in the same area. When complete put back in the right fuse!!
Apr 03, 2013 | Audio Players & Recorders
Hello i have a marantz pm-47 amp that keeps blowing every time i plug in the power feed to the amp board i have changed the 2 caps on the board but still have the same problem i checked voltage for...
Hi mas_66,
Make sure that the fuse is the same rating with the old one.
If still symptom persist, I've suspected that your output IC is shorted.
You may hang this IC, then power up the unit.
Observe what will happen, if this cure the symptom then this is a clear indication that this IC is shorted and made the fuse blown while it is in the circuit board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 08, 2011 | Marantz PM-68 Amplifier
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
I have a marantz integrated stereo amplifier PM-57 and it keep cutting out regularly. its sounds like a relay is clicking in and out. what can i do?
please disconnect loudspeaker one by one until the problem is goen -and fix the bad one by change the cabel first and the speaker second if all above does not solve the problem send your amp to service center to repair.
May 27, 2008 | Marantz Audio Players & Recorders
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
Marantz PM-15S1 2-Channel Amplifier Logo
614 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
