Question about Canon PIXMA MP530 All-In-One InkJet Printer
My canon pixma mp530 makes a loud noise most times when it powers up and when i print a document. It works OK otherwise.
My MP-530 would try to boot up making a noise like something slipping or grinding, ending with ERROR Code 5100.
Solution: Open the Lid. The drive belt was loose and not able to drive the carriage. There is a gear on the right side of the carriage and a pulley on the left side of the carriage. The spring which holds the pulley tight is missing or broken. I was not able to see the tension spring. To put tension on the pulley, to tighten the drive belt, I cut a Popsicle stick into a wedge and inserted it into the middle slot right of the pulley.
Close the lid and power back on. Runs like new. Hope this helps.
Posted on Aug 03, 2009
Canon MP530 grinding noise. Tried 2 solutions in this forum - didn't work. Noise happens when printer is idle, after printing. Print head (carriage?) tries to 'park' when noise happens.
Someone, somewhere, suggested removing the cartridges and then the printer head, putting them back, and unplugging and then rebooting the printer. I do believe this has solved my problem. I had been living with the horrid grinding sound for many months, and now it is gone. I am crossing my fingers that this will last, because otherwise it's been a great all-in-one.
Nov 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My CANON PIXMA MP530 is showing the alarm, "Document in ADF."
Open the top cover of the ADF and look for a rectangular hole with a lever stuck down. That lever should only go down when a paper is placed in the feeder, and sometimes they get stuck in the down position. A bent paper clip might help you lift it gently...
Jun 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Loud clicking/vibraton noise after printing when heads reset
Follow instruction into the manual and to a reset to factory defaults. This should align and correct the issue. If not you have defective heads. Contact the factory for warranty replacement.
Jan 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 will coply but won't print
sir,
Try to replace the cartidge maybe your cartidge is not fit to work properly and also the ink is not compatible with your printer
then after you replace the cartridge do the nozzle cleaning until its ok.
yours,
alecz
Apr 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 clicking
it is nothing to do with a phone jack, trust me this sounds like internal crunching and munching... but as reported by the others, no jams, no printing errors, just loud clicking and clunking!
Feb 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax in memory
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Oct 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
796 people viewed this question
old marine
old marine
