Question about Kenmore 75085 Air Conditioner
No power i got the unit from my brother, who bought it a year ago and never used it. i plugged it in and it has no power. the green light on the plug in does not come on. i tried hitting the reset button and switching power outlets, but nothing has worked. if there is a fuse inside, does anyone know where it's at?
    President:
  • 1,124 Answers
Do you hear a humming noise ?
After sitting the compressor might take some timeto kick on..
And after sitting - the blower fan can get stuck..
Take the front cover off.. If you see the big barrel fan - give it a good spin by hand..
That sometimes gets it going if stuck..
Note;
We are helping people here every day on a points system. If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Posted on Jul 31, 2009
I am wiring a 4 pin trailer plug into my 1998 Dodge Durango's factory tail light harness. This vehicle did not come with a tow package of any sort. I installed the hitch and am trying to install the plug...
Hey brother,First thing you need is the relay box that changes everything to the newer harness.Can't wire it like you are,that's old school,till you have that change over box.Use a test ligh to make sure which is left and right signal on truck.Green goes to right,yellow to left,brown to running lights,and white on those 4 wire flat plugs IS defintely ground.Mount the little box/unit to your frame,plug an extension 4 wire flat plug to it,Hook up a seperat ground wire between the trailor and truck with a set of male female wire ends for extra grounding and put on a self tapping screw in frame or on a accesable bolt.Plug it all together and good to go.I've done thes things for years on end,and when they went to this new wiring setup,all I needed do was use that change over box.THAT's progress Bro.
Sep 20, 2013 | 1998-2003 Dodge Durango Tail Light Guard...
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
I rec'd a The Sharper Image digital photo album with keychain as a gift two years ago. I have installed the 55 pictures from my pc to the unit. This unit will only work if I keep the unit plugged into...
It is for sure a battery related issue ..either the battery do not have contact like it should with the main board ...or it is damaged..and do not hold the power anymore...(it is possible if it was kept uncharged and not used..or not formatted well in the first place..
try to open it up and see if it is any visible loose contact ...and also to see the properties of the battery to get a replacement or at least one that fist with the same characteristics..
Dec 27, 2010 | Cameras
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Re: Logitech GT Force Wheel
I know this sounds stupid, but mine did the same thing until I remembered that it also has a power supply that has to be plugged into an outlet. I had simply connected the USB cable and got the green light on the top left hand side but it wouldn't respond otherwise. Sorry if you already have this checked but it solved the problem for me.
Jan 02, 2008 | Logitech Driving Force Pro (963293) Wheel...
Kenmore 75085 Air Conditioner Logo
328 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
