Question about Garden
Lawnmower keeps slipping power drivebelt over rear sleeve
    President:
  • 1,273 Answers
Usually, when the machine throws belts, the best thing to do is to replace the belt. Sometimes they are worn out or stretched, and you just can't tell it. I had a pristine looking belt on a pretty new mower doing the same thing. I replaced the belt, problem solved.
Best regards, and happy mowing! --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 31, 2009
Ac compressor cluth is worn
Probably not a good idea as the drivebelt will wear out pretty fast. The belt may not have the proper grip to the pulley and will continually slip. Maybe the "cluth" is frozen and will not turn. Best to have an expert look closely at this.
Feb 01, 2015 | 2004 Jeep Grand Cherokee
Scotts lawnmower model 1742g/drivebelt
No
Go to a Small Equipment dealer for a
picture & parts
Aug 18, 2014 | Cars & Trucks
Belt came off 97 achieva how is it put back on
to replace drive belt rotate tensioner pulley clockwise then slip on new belt look under hood on the radiator shroud for drivebelt routing diagram.check drive belt tensioner for damage or looseness because very seldom drive break either cracked worn or drivebelt tensioner faulty.
Aug 06, 2013 | 1994 Oldsmobile Achieva Special Edition
Etesia drivebelt
This is posted in the wrong product category, please post again.
May 26, 2012 | Cars & Trucks
07 Lincoln MKX how do you get tail light assembly out after removing the 2 screws. won't budge!
The two screws hold the rear of the tail light in place. The front of the tail light is held in place by two pins that fit inside two sleeves. After removing the screws, gently rock the lens and pull straight back toward the rear of the car. The pins will slip out of the sleeves and you have access to the bulbs.
Feb 09, 2011 | 2007 Lincoln MKX AWD
Squealing from the drivebelts area
Most likely cause is a worn or lose belt. Look at the inner surface of the belt, if it's shinny, replace it. If it looks OK make sure it's not slipping. Tighten the belt to keep it from slipping.
Oct 18, 2010 | Nissan Xterra Cars & Trucks
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
Fan belt
slacken the alternator pivot mounting bolt and the adjusting arm bolt then move the alternator towards the engine . slip the drivebelt off the alternator pulley.refitting is the revers sequence of removal, but before titgtening the muonting and adjusting arm bolt, tension the drivebelt.
Jan 16, 2009 | Mazda 323 Cars & Trucks
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
