Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic LIFI rear projection quit working
I have a Panasonic PT-50LCZ70 rear projection LIFI that quit working while I was watching it. Ironically, it quit working about 3 minutes after the switch from analog signal to digital in June. It would turn on for a few minutes and eventually it would not turn at all except to show the blinking light trouble code. I took to the local Panasonic service center and was told it was the LIFI lamp and that Panasonic would cover labor and parts to replace it. TV was 1 1/2 years old but Panasonic has extended its warranty on the lamp to 2 years for labor. When I got it back it worked fine for 2 days then it went out again. I took it back to the same shop and today the called me and said it would be $1300 to repair it. I was told the "chassis??" needed to be replaced and the part alone was $1000+. Since the TV only cost $1500, I am not going to pay that much to have it repaired. The repair shop has a 30 day warranty on all repairs but I am sure they will say this is a different problem and it wasn't their fault. It's pretty hard for me to dispute it since I know nothing about it, but I have a feeling that I may be getting screwed. The Panasonic site shows replacement parts and prices and I can't find one that is nearly that expensive. I would appreciate any thoughts on how to handle this from techs who are familiar with this type of repair. Should I blame the repair shop and push them on their 30 day warranty, or should I approach Panasonic to make it right or should I just accept my loss and junk the TV. Thanks.
  • 2 more comments
  • dennjd Jul 31, 2009
    The part costs more than the TV??? I am beginning to think that the repair shop doesn't really know what is wrong with it and is doing a wholesale replacement of parts at a high price just to get rid of me, knowing that I would have to be a complete idiot to go along with it. Although I agree with and appreciate the previous answer, I would like to have more information or opinion as to the likelihood that the second repair requiring replacement of the chassis was caused or would have been related to the initial repair which was the replacement of the lamp. I just can't see the repair part costing so much being required unless the TV fell down the stairs. I was dealing with Panasonic service and they did refer me to this shop which is about 50 miles away. It was the closest authorized repair shop. I would like to hear from someone who is familiar with this specific type of repair. Thanks.
    I know this is a different part and I doubt they put the wrong lamp in it. I presume the LIFI lamp for this unit can't be replaced with the wrong lamp. I believe they have to replace more than just the lamp when the lamp goes out.
    Warranty for the TV is 1 year parts and labor and the bulb is 2 years labor and 5 years on the original bulb. So if they say it is something other than the bulb, then there is no warranty now. The only thing going for me is that the repair shop has a 30 day warranty on their repair which I'm sure they will say their repair is still good and that the current problem is new. I agree that I am not going to spend any more money on the TV and I intend to try to make them settle the situation with some type of buyout. I was just trying to understand better the possible relationship between the original replacement of the bulb and the current need for a repair to the chassis. If the power supply was the problem originally and they missed it then it may have caused the original bulb to blow out and the motherboard to fry. That would make sense since the original repair only lasted only two days. If it was the power supply then the original repair would not have been under warranty and I would have had to pay for it but I'm sure it would have been at a lower cost. Any additional thoughts or ideas would be appreciated.
  • TV Tech
    TV Tech Feb 12, 2012
    Read my comments below. They're blowing sunshine for brownie points. And rethink your drink....
  • 11,896 Answers
If this tv is under warranty, it should be fixed no matter what the problem is, I would try and make them buy it back. Otherwise all this stuff you are getting done I think is a joke. All these problems sound like a faulty power supply which is extremely common in newer electronics. I can't tell you whether it would be worth to fight them on it or not, I personally would get anything in writing and copy of warrant so you have some info to back yourself up on. I would not spend any more money on the tv. I would try and get everything for free, or make them buy it back
Posted on Jul 31, 2009
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Jul 31, 2009
    Get a new tv
  • TV Tech
    So Nathan, you're going to get your Auto Mechanic to replace one of your headlights, then take it back days later and blame them because your battery went bad because it's been in your car for the last 4 years wearing out ? You're a rip-man...that's what you are. Same with Blame-Boy above...
  • TV Tech
    Do you really expect the mechanic to give you a free battery when the only warranty you have is on the headlamp? You can't blame a tech for damaging a chassis when the Lifi is on the rear right and the chassis is on the rear left side of the cabinet. Another analogy --- You going to blame them for the exhaust pipe falling off because the lifted the hood and installed a headlamp ?
    I've met people like you. You're always thinking that the WHOLE TV set has a Warreanty on it because one little part was installed.
Is it just me .. or is TVTech a very unhappy guy about his role in life.
I have yet to see him post anything of any value to this site, only complaining about how the consumer is trying to stand up for his/her rights.
Get a life buddy and change careers if the technology used for TVs today is phasing out an old dinosaur like you.
Posted on Aug 06, 2013
    President:
  • 1,734 Answers
The chassis is indeed a different thing than the Lifi lamp. It is the motherboard of the TV. Maybe the built in a wrong lamp which damaged (or shortened) the motherboard. But this is difficult to prove.
A LIFI lamp is also about 1/8 the size of a conventional projection lamp. This is said to make for faster turn-on time—about 10 seconds. I did not find it to be quite this quick, but more like 20 seconds from a cold turn-on to a full brightness image. Nevertheless, that's significantly better than a conventional projection lamp.
If you need a service manual for your TV, I found one at http://manualfox.com/manual0.htm
    President:
  • 2,777 Answers
Wow, sorry to hear about your issue, that's a nasty situation to say the least. First off I would call Panasonic to tell them about the issue, that is if they actually paid for the first repair and you have already dealt with them directly. You have rights as a consumer and this should definitely be covered by the 30 day warranty if nothing else. If Panasonic was never involved, or if they tell you to deal directly with the shop then definitely push them on the warranty, this is the cost of doing business on their part. If you take your car to a mechanic, they fix it, and you get it back and it breaks down with the same exact problem 2 days later they are required to guarantee their work and you wouldn't have to pay for the repair. If the problem was completely different (in manifestation I mean, say for example the air conditioning went out when the first problem was that the engine wouldn't turn over) then the burden is on you. There is actually a part that costs that much to replace, here is a link to it for an example:
http://www.partstore.com/Part/Matsushita/Panasonic/PT50LCZ70/Matsushita/Panasonic/LSXY1151/New.aspx
But, if the problem is the same, meaning the TV went out the first time, wouldn't turn on, and did the same thing the second time, then they should have the burden on them for the repair. They should be able to go through Panasonic if anything else, you could make the argument that somehow they caused the second problem by doing the work they did. The fact that you had two major parts go out within days of each other is definitely highly suspicious and if it were me I'd definitely make them fix it.
Hope this helps
Tim
  • TV Tech
    Nice quote...right from the manual.
    Add this part that you conveniently left out --
    You have rights as a consumer and this should definitely be covered by the 30 day warranty "that covers the part replaced"
    If I replace the LIFI, that doesn't mean your chassis or cabinet or remote control or your screen or anything else has that warranty on it.
    And if you want to blame improper LIFI installation...then Riddle me This Batman :
    How can a 12 Volt and 5 Volt power line from the chassis get damaged by a Lifi unit that's 28 inches away....buffered by it's own power supply, and separated by photoisolators eh?
    The engineers are smart about buffering the low voltage circuits from the high voltage circuits.
    Anybody here a REAL Tech ? Do you go to the Panasonic Training? You pay your yearly subscriptions, pass their tests, get rated each and every time by customers doing warranty work for Panasonic?
    I do.....
    Don't GUESS at what rights you have as a consumer....study them. Hearsay is not good advice.
Panasonic PT-50LCZ70 Shuts off then starts up again.
Sounds like a power board malfunction. Find a honest tv tech.
Nov 10, 2013 | Panasonic PT-50LCZ70 50" HDTV
MY PANASONIC TV MODEL NO. PT-61LCZ7 TURNS OFF AND TURNS BACK ON WHILE WATCHING TV, WHAT COULD THIS PROBLEM BE
I have the same problem, same model #. 61lcz7 for those tech that say just repace the bulb. This is a lifi MODEL the bulb cost $300 dallars and another $300 laber.
Feb 17, 2012 | Panasonic Televison & Video
I cannot locate the bulb in my Panasonic PT61LCX70-K
This model uses the LIFI lamp ***'y. It's not a customer servicable part so you'll have to call authorized Panasonic service center to change. However, the lamp does carry a 5 year warranty so do not fear. To answer your question, the lamp is on the right side of the unit as you look from the rear.
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Panasonic PT-61LCX70 61" HDTV
My tv is making a clicking noise and not turning on. can it be fixed?
get you manual and see it it is blinking the code for lamp. call Panasonic even though it's older it might be coved under LIFI lamp repair warranty. 1-800-211-7262
Jan 01, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
Tv stoped working - LIFI PT56LCZ70
This unit has a very complicated bulb replacement procedure. You would be much better off if you contact a panasonic service center and have them replace it. Bulb assy is pretty expensive as well. The part # is LFS4000PA1EB but you will have to go to panasonic to get it. Good luck. Thanks
Oct 27, 2009 | Panasonic PT-50LCZ70 50" HDTV
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
