Question about E-Machines Computers & Internet
How do Iplug the power switch wires in the corect place on the mother board? for the emachine T2824
    Novelist:
  • 129 Answers
Hi.
Did you try to open your CPU casing to find the socket in your motherboard witch is totally fix with the power switch wire. The power switch wire are two forms, there is a 20 pins and 24 pins. If your power switch socket is only a 20 pins, you need to put only the 20 pins.
The 24 pins is not totally combined in power switch wire. If your motherboard power socket contains only 20 pins, so remove the 4 pins in your power switch wires. "Good luck!!"
Hope it may helpful for you!
Regards
ICmanServer
Posted on Jul 31, 2009
I have emachine t seris t2862 desktop and I donnot know how to connect power swich in mother board please help me
On the motherboard there will be a small set of connectors marked FPANEL, next to each of these will be a set of letters (usually PW, RES, HDD, MSG) and an earth pin, From the power switch you will see a two wire set normally black and white ending in a connector, this connects to the PW pins on the FPANEL
Jan 06, 2011 | E-Machines eMachines Refurbished EMA...
Emachine d2880 power on switch is bad. How do I work around? Is there a way to short the pins on mother board to turn on my PC? In words do you have connection details for power on switch wires to mother...
In your computer you have a power switch located on the PC chassis, you will find two wires coming off of it. At the end these two wires you should find a black 2 pin push plug. This should be connected to your mainboard. On your mainboard, the header for LEDs, hdd, power etc, you should see two pins labled power. Switch push plug goes over these two pins or these two pins labeled power can be shorted with a screwdriver, however this can be risky as it is very easy to touch other pins in the process and kill the mainboard. Rather use a push plug!
You can also read my guide as your computer my not be POSTing, my published guide is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
All the best!
damnor01
Nov 22, 2010 | E-Machines eMachines Desktop PC
My computer won't turn on. I cleaned the Air spinner thing, checked the mother board, and everything was fine. The computer is an Emachines T2824. Can i have some assistance on how to get it to turn on?
If the machine is doing nothing at all when you press the power button, chances are your Power Supply Unit (PSU) has failed. If this is the case, the only way to fix it, is to get a new PSU.
Nov 03, 2010 | Computers & Internet
Emachine t2824 board diagram
Here is the diagram that shows you how to hook up the wires:
http://www.fixya.com/uploads/images/284ECAC.png
If you still have no video then reseat the memory one stick at a time in one slot at a time.
If you still have no video then reseat the cpu into its slot.
If still no luck try a different stick of RAM by trying it one slot a time.
Last step, unhook the power connectors from your device so the only power connectors that are connected are the power to the motherboard and the p4 connector to the motheboard. Also make sure your power supply is set to 115v. Its the red switch on the back of the power supply.
If none of this works, then the motherboard is bad. Hope this information helps.
Ben
May 24, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
EMachines 2824 not powering on
you can check also by removing the boards.you can check the mainboard outside in the box..you remove the mainboard and check if the mainboard is not shorted with another devices.
Mar 07, 2009 | E-Machines (T2824) PC Desktop
On and off connection to board
The wires from the on-off switch only go to the power supply. From the power supply there will either a 10 or 14 pin connector that is plugged into the motherboard.
Feb 25, 2009 | E-Machines eMachines Desktop PC
Can u possibly tell me where i might be able to download a schematic for an EMachine desktop computer model #T2742? It is out of warranty and was donated to our church and we need to know where to...
Hi dallasblue08,
Here's a diagram of what your looking for:
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
Hope this helps!
Mark
Jan 04, 2009 | Computers & Internet
Emachine 2685 no power up
from the spec of the motherboard it should be one of the pin headers near the Bios battery (looks like a coin on the mobo)
hopefully (if you look close enough) it should be marked pwr
Oct 13, 2007 | E-Machines eMachines W2686 PC Desktop
Computers & Internet Logo
1,327 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
