That is an older model set that still has the backlight inverters. It may be one of those and it may be the power unit. Mitsubishi LT 52244 TV Parts
SOURCE: how munch would it cost to fix my Mitsubishi TV -
Depends on the damage, your problem is vaque.
Best Buy, Radioshack both send off items for repair.
Find a local tv shop, if they fix it for less than $200 i'd be surprised.
depending on damage location, and severity i estimate $200-$800
Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Hi Rick,
It appears to be a case of backlight failure. since you have replaced all the boards, inverter is ruled out. Some of the LEDs in the backlight array may have gone bad. Fault is repairable, but needs care and experience of opening and repairing the LED panel. Good luck.
