Question about Hayward Pool & Spa
Filter hums when turned on will not kick on - Hayward Pool & Spa
    Problem Solver:
  • 6 Answers
Your motor is what is termed as "locked up" This is a term to describe either a motor armature which will not spin because of a mechanical or electrical problem. Electrical issues can sometimes be easy to fix.
If the start capacitor is bad, it simply needs replaced in order to fix your problem. Most all pool pumps have a Start capacitor located in a small metal *** attached to the motor. You will either need to have a capcitance tester to see if the capacitor is bad, or buy one and replace it if you have money to burn.
I say that because the problem causing the hum could also be due to a mechancical failure, and not so easy to fix. If the bearings in the motor are run down, seazed or damaged, the motor will just hum and not pump. same result ( humming motor)... different reason. Most electricians or air conditioning or mechanical service companies could test the motor and suggest which repair is needed.
Posted on Aug 23, 2009
  • Mwingun Aug 10, 2011
    Could a storm or possible lightning strike cause the capacitor to go out?
My rooftop air conditioner is making a humming noise, but will not blow out air. The fan will not kick on manually from the thermostat. The humming stops when I turn the thermostat to off.
check the capacitor of the fan motor may be it was bust u can see physical by the size bulge if u found damage. change it to new one with same rating then it will fix your humming problem.
Aug 20, 2016 | Heating & Cooling
2000 nissan altuma fuel problem
Listen for the fuel pump to kick on when you turn the key on(just to the on position you don't need to be turning it over) sounds like a humming or low buzzing sound. It will kick off when the system is pressurized. If you don't hear this your fuel pump is bad. You can go ahead then and check the fuel filter then the fuel pressure regulator. That should get you up to the injectors. All of these components are not serviceable and if you find one that is bad it should be replaced.
Jul 20, 2013 | Cars & Trucks
2001 mitsubishi diamante not turning over
Try turning the key on and listen for the fuel pump to kick on it'll be a hum coming from the fuel tank area. If you don't hear anything then its a bad fuel pump. If you do try turning the off and on several times leaving it in the position till the humming stops then turn it off and repeat a few times then crank it if it starts then the fuel pump is weak or a clogged fuel filter which isn't allowing enough fuel to pass thru to open the injectors.
Dec 21, 2012 | 2001 Mitsubishi Diamante
My 1996 Automatic Diesel Toyota Townace truck went through high water at a rapid speed, made a humming/spinning/turning noise and stalled out. After a while is appears to want to start but will not kick...
1996 Automatic Diesel Toyota Town Ace, when hot meets cold that's what can happen. It may take a few days wait but check your filter and bearings. Fuel needs to flow to the filter and a seriously strong battery power is needed to kick it over. Idle it to let off smoke and clear exhaust. That should hopefully work.
Jul 18, 2011 | Toyota Pickup Cars & Trucks
Engine won't crank. seems like no fuel getting to engine. Had the dealer replace the fuel relay worked for several days... replace it again myself....but still won't crank.
SOUND LIKE FUEL PUMP FAILURE FUEL FILTER LOCATED ON THE FUEL PUMP ASSEMBLY REPLACE THE SOCK FILTER IT COULD BE PLUGGED IF FUEL FILTER OKAY OR CANT BE REPLACED YOU HAVE TO REPLACE WHOLE FUEL PUMP ASSEMBLY WITH FUEL FILTER TO REMOVE FUEL PUMP YOU NEED TO REMOVE SECOND ROW LEFT HAND SEAT, REMOVE THIRD ROW SEAT,REMOVE SECOND AND THIRD ROW SEAT BELT BUCKLES MOUNTED TO THE FLOOR,REMOVE LEFT HAND CENTER PILLAR,REMOVE LEFT HAND REAR TRIM PANEL, REMOVE LEFT HAND REAR SIDE DOOR KICK PLATE AND WEATHER STRIPPING, REMOVE SECOND ROW REAR CENTER CONSOLE AND BASE IF EQUIPPED, REMOVE THE INSPECTION HOLE COVER UNDER CARPET BY TURNING RETAINER 90 DEGREES REMOVE ELECTRICAL CONNECTORS, REMOVE EVAP HOSE.REMOVE SUPPLY HOSE, REMOVE LOCK RING USING SPECIAL TOOL J - 46214, REMOVE FUEL LEVEL SENSOR, REMOVE FUEL FILTER AND THE FUEL PUMP ASSEMBLY.BESURE DEPRESSURIZE FUEL SYSTEM BEFORE DISCONNECTING ANY FUEL LINES AT THR FUEL TANK.
Jul 16, 2011 | 2004 Nissan Armada
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
Liftmaster - motor hums, doesn't turn. Removed
My neighbor guy, who knows a lot about stuff, told me to get a new one.
Good solution.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
Pool & Spa Logo
779 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
