Question about Kenmore Dishwashers
We just bought our house and the dishwasher leaked when we used i
We just bought our house. The first time when we tried to use our Kenmore dishwasher 587.1546580 and it leaked. I remember when the home inspector did the inspection half a month ago and run it through a whole washing cycle and no leakage. What could have happened?
    Problem Solver:
  • 8 Answers
The best way to determine what could be wrong is to take the side panel off the washer (usually only held on by four screws). Once this is off, have a flashlight handy, and start a wash cycle. From there, it's just a matter of following the water back to the source. Most likely candidates; leak around the float valve switch (toward the bottom front of the cabinet) or the door seal, but you can't go wrong by tracing back where the water is coming from, and THAT way, you won't be buying the wrong parts, you can order what you need! Good Luck!.
Posted on May 21, 2011
  • 20 Answers
Check around the bottom of the seal on the door . It might have a build up of old soap and food this will cause a leakIf you clean it good it should take care of it.
Posted on Jul 31, 2009
Kenmore Dishwasher 17372 is leaking water through tub water inlet
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wqeyrad
Jan 07, 2010 | Kenmore 24 in. 17372 / 17374 / 17379...
Leaks water from under dishwasher, some one suggested the fill valve assembly needs replacing???? kenmore
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Does not fill or drain.
Test the timer control board and the impeller pump.
pump is tested by energizing. Board is tested using a multimeter.
Observe strictly safety rules.
May 21, 2009 | Kenmore Dishwashers
Dishwasher seal issue
I use ge silicone clear sealant it is flexible adhesie that can handle water and heat
You can get this at Ace or big box stores you do not need a big tube
FIX:
1 Open dishwasher door
2 gently pull rubber seal away from dishwasher guide You do not have to remove the entire seal unless it is loose just keep pulling until you feel the seal staying on dishwasher
3 put a small amount of clear sealant on loose seal(side facing housing) and small amount on dishwasher guide ( dip your finger into water so that it does not stick to your finger)
4 press the seal into place on dishwasher housing
5 wipe excess with a damp cloth be sure you do not get any on seal side that faces dishwasher door
6 Allow to dry over night
Good Luck
Jan 02, 2009 | Kenmore Dishwashers
I bought a used dishwasher when I start it it makes a loud noise
it is most likely leaking from the drain or supply tubes you must remove the dishwasher again and check the tubes for a loose band or clamp. Or a cracked hoes!
Dec 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher Leaking
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwashers Logo
88 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
