Question about Garden
My self propelled troy bilt mower will not propell. i can lift it off the ground and the wheels turn. i changed the belt this did not help. can anyone tell me if the model 12ag836e711 have the recall for this.
  • 162 Answers
According to the troy bilt site there ar no recalls on any lawn mowers.
here's the link
http://www.troybilt.com/webapp/wcs/stores/servlet/DisplayContentView?langId=-1&storeId=10001&catalogId=14102&pageName=siteFooter/productRecalls/productRecalls.html
Posted on Jul 31, 2009
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
My lawn mower starts and cuts fine, but it will no longer self propel even though the wheels actually turn when I lift the rear wheels off the ground.
Have you checked the belt? There is a belt that runs from the shaft to the transmission that gets worn and streched out. It will spin the tires, but not under a load. I'm sure thats the problem! The cover is usually located under the deck.
Sep 09, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Model Series 860
sounds like a bad tranny if this unit is under warentty DO NOT ATTEMPT REPAIR . if you attempt to repair this yourself you can void any warrenty
Sep 19, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
416 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
