Wall mounting Panasonic Viera 32" tv
I have a Panasonic Vierra TX32LXD700 LCD tv and have mounted it on the wall but cannot remove the base stand.
  • 3 more comments
  • Killianc Nov 25, 2007
    I have a Panasonic Vierra TX32LXD70D LCD tv and have mounted it on the wall but cannot remove the base stand.
  • jaypuzzle Dec 24, 2007
    can not remove the base for mounting
  • richard lee Apr 27, 2008
    has anyone found a solution for removing the stand from the Panasonic Veira 32" LCD. I am considering taking a hammer to it.
    email me.
  • Anonymous Dec 23, 2008
    how to remove the base
  • Sandeep Varma Sep 11, 2012
    I too have the same problem, not able to unmount the TX32LXD70D LCD from the wall. Can somebody detail the procedure?
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
  • 1 more comment
  • PixiePaige Jul 07, 2011
    This is EXACTLY RIGHT!!! I have Viera Plasma and the stand is identical set-up!
    YOU ROCK gacba!!!
  • pillarstchr Jul 16, 2011
    Thank you so much! You explained it perfectly and we FINALLY got it out after reading your post!
    Thank you so much. We followed your directions and we were able to successfully remove it. Sure was a pain until I found your posting.
Took me a while to find this. Remove the two lowest screw, holding on the plastic back, in the centre and it drops out.  -- Andrew
Posted on Apr 27, 2008
Took it off the wall of the camper we just bought. Would like to use it in my guest bedroom, but the stand is gone. Can you help locate one for me?
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there.
Here is a link to one example currently available for an Emerson TV:
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Aug 11, 2011 | Televison & Video
Can remove stand from television
Yes you can remove the stand from the television for wall mounting purpose.Just unscrew the four screws marked by the yellow circles. Lift the TV up while somebody holds the base down or it will lift along with the TVand fall. Make sure you take help from one more person while doing this.bobhifi_22.jpg
Mar 28, 2011 | Panasonic Viera TH-42PX80U Plasma TV
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
I bought a used panasonic TH-50PZ85U plasma TV that was wall mounted. I need a pedestal base. Called Panasonic 3 days ago and the have to "research it". Can you help? km
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal you know where I can find one?
Jul 14, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
Feb 07, 2010 | Sony KDL-32S3000 32 in. LCD Television
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Dec 01, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
5,097 people viewed this question
Top Televison & Video Experts
