SOURCE: After Market radio install on a 2001 Passat
Metra makes a preamp harness that you can use if you have the partial Bose system. My A4 had that (where the front speakers were run off of the headunit with speaker-level feed, but the deck put a line level signal to a rear amp to power the speakers). This harness would let you use the aftermarket deck with your factory speakers, if you have the partial Bose system. Best bet is to do a Google search for "Metra 2001 Passat" or something like that and I'm sure it'll show up.
SOURCE: e- brake by-pass code
This is the best bypass method for the Dual XDVD8181. Althoug i am not sure if it works for any of the similar models b Dual. My guess it will.
1) Groun the emergency brake wire.I used the radios black groud wire.
2) Insert a DVD and let it play until you hear the sound.Copied DVDS will not work for this.
3) Press STOP on the remote TWICE.
4) Using the remote enter 26604 and press enter .If done correctly you should hear it beep and the video will be viewable.Good Luck.
0
SOURCE: proton jumbuck radio/cd removal & replacement with single DIN
take a flatblade and pry the panel that is clipped in around the radio.remove the 4 bolts holding in the radio.
SOURCE: FORGOT CODE FOR JENSEN VM9412 CAR RADIO
I took my radio out of the car I sold and tried to put it my other car and it keeps saying enter entry code, its a jensen vm5912 whats the problem.
SOURCE: radio code for alpine radio model c33 din us bmw z3 al6bdut078086
Alpine BMW codes available online here:
https://www.carstereocode.com/unlock.php?mk=6
