Question about Behringer EUROPOWER EP2500 Amplifier
EP1500 will not power up - Behringer EUROPOWER EP2500 Amplifier
  • 313 Answers
Check at the back for the small round fuse cartridge unscrew and chek the fuse is ok adn check the fuse in your plug
Posted on Jul 31, 2009
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
Behringer EP1500 not working
Possible that the power section has failed and it could be due to fault in the power supply section . Unless the unit is opened the damage cannot be confirmed to be just a fuse or a faulty SMPS.
Jul 03, 2012 | Behringer Audio Players & Recorders
I have a behringer EP1500 amp, connected to a behringer mixer VMX100. i am getting a popping sound, the sound is random, it happens at various times, so i cannot say it always happens after i have...
hi,
check the power outlet socket to which the amp and mixer is connected. if there is any loose contact in that power socket, this problem can occur. try to use a good surge protector with emi filter for connecting the amp and mixer.
ok
Dec 29, 2010 | Behringer Audio Players & Recorders
I have an Intertherm EP1500 portable heater. It's 7 foot long exactly, 120 Volt, 1500 watt. Intertherm was bought out by Cadet and this model equates to the Cadet model EPA 1500. I need to find what I...
I would take this part out and take it to a local mechanical supply house in your area. The service people are very knowledable about heating and a/c parts and they can physically look at the part to see if they have it in stock or if they can order it. good luck
Dec 11, 2009 | Heating & Cooling
How to bridge the amp
How many channels does the amp have? 1,2,3,4? im going to assume its only a 2 channel amp when I say, there should be a 2 positive and negative channels, do your speaker wires off of 1 positive and 1 negative of the channels to the speaker.
Dec 11, 2009 | Behringer EUROPOWER EP1500 Car Audio...
We've got a signal on the mg32fx14 mixer from the microphone. There is no sound from the speaker. We tried the Group out there is no sound. So where do we connect the output from the backpanel of the mixer...
mg32fx14 monitors intermitently cut off, smoke comes out the back . aux 2 changes aux 1 and aux 2 at same time. 1 channel will over drive then change channels without changing enything else and its ok eny ideas or do i have a boat ancor
Apr 02, 2009 | Yamaha Mg3214fx 32 Channel Mixer With Fx...
Behringer 1500 red light. Amp powers up fan comes on then a have a channel A red light that doesn't go out. No Sound
RED LIGHT MEANS THERE IS EITHER WIRES TOUCHING OR A BAD GROUND. IN WORSE CASE SCENERIO THE A CHANNEL IS BLOWN
Feb 23, 2009 | Behringer EUROPOWER EP1500 Car Audio...
Europower 1500 amp
COULD BE FUSES ...CHECK THEM WITH AN OHMS METER.ALSO IT MAY BE THE POWER SWITCH IT MAY HAVE GOT BUMPED AND BROKE INSIDE THE SWITCH JUMP THE SWITCH WITH A JUMPER WIRE BE VERY CAREFULL
NOT TO GET SHOCKED IT COULD HAVE A 120 VOLTS AC AT THE SWITCH GOOD LUCK
Jan 12, 2009 | Behringer EUROPOWER EP1500 Car Audio...
Behringer ep1500 versus behringer eurolive b215 X 2- pa speakers.
The Amplifier will have wierd, notched, circular speakon cable connectors on the back, two, one for main left and one for main right. Press the button in on your speakon cable connector and twist it and lock it into place on the amplifer for right and left attachments, then do the same to your speakers.
Hopefully this helps.
Michael Lazar
http://www.AudioholicBlog.com/
Aug 27, 2008 | Behringer EUROPOWER EP1500 Car Audio...
Church System
Hi there Apostledavis
I don't know this specific system and you haven't mentioned whether you have just installed it or whether it has only just started causing problems but did work ok before?
However, there are a few things I would look at. I would also check the system right from the input bit by bit to see whether the problem is an input or output one.
1) Completely isolate the amp from all other equipment and connect a signal source to the left input only and then the right input only. If they sound much the same, the amp is probably ok. If they don't then the amp is probably faulty.
2) Check whether the monitors and amp both have weak output on the left channel.
3) Check and balance settings.
4) Check the speaker phasing.
5) Check all the interconnections, plugs and sockets. You could squirt some switch cleaner on a rag then wipe all the plugs before putting them back in the sockets.
6) Check the Behringer VU meters and make sure they indicate a reasonable balance on both channels.
7) Check that the channels sound ok when using headphones.
8) Check all faders and sliders by moving them vigorously to clear dust from the tracks. (Not applicable if digital, of course)
Hope this helps
Jan 27, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
133 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
