Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Pool filter hums when turned on pump is not kicking on
    Scholar:
  • 34 Answers
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
If your pump has been leaking water it could be that rust has formed on the inside and is preventing the motor from operating properly. Which requires more aggressive dis-assembly to diagnose.
You can take it to a motor repair shop if the above listed doesn't work.
Posted on Jul 31, 2009
I have an in ground fibreglass saltwater pool and the water will filter will not pump.
a humming noise is a frequency noise meaning the motor is not running
check / replace the start/run capacitor for the pump motor
call an electrician for a proper diagnosis
Dec 28, 2016 | Pool & Spa
Motor hums but won't kick on
motor high limits tripping defective motor replace motor or whole pump
Jun 14, 2014 | Pentair 1 HP Challenger Pump
Pool pump motor does not turn pump when timer trips
does it hum at all.. turn the impeller with a small rod se if it will sart up..
Dec 31, 2013 | Intex Wet Set Water Filtration Filter Pump...
Waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Apr 02, 2013 | Waterway Pool & Spa
Pinnacle high performance one hp have a reset button
if humming and not running bad start up capacitor or bad motor replace pump be safe
Apr 20, 2012 | Pentair 1HP Pinnacle High Performance...
When I turn on my intex pump model # 633 all it does is hum. Pump is 1 year old.
hello,
what this indicate is that there is a gap between the pump and the filter
In this pump, or filter. There is an "air relief"(air gap ) on the top of the intex filter pumps and you must bleed the air by turning the knob on the top counter-clockwise just a little.
it is a filter gap problem.
what yo are to do to fix up this problem is to fix up the filter properly on it position that is remove the filter and then reposition it the problem of hum sound will be solve .
thank you and thanks for using fixya.
Jul 07, 2010 | Intex Pool & Spa
Filter hums when turned on will not kick on
Your motor is what is termed as "locked up" This is a term to describe either a motor armature which will not spin because of a mechanical or electrical problem. Electrical issues can sometimes be easy to fix.
If the start capacitor is bad, it simply needs replaced in order to fix your problem. Most all pool pumps have a Start capacitor located in a small metal *** attached to the motor. You will either need to have a capcitance tester to see if the capacitor is bad, or buy one and replace it if you have money to burn.
I say that because the problem causing the hum could also be due to a mechancical failure, and not so easy to fix. If the bearings in the motor are run down, seazed or damaged, the motor will just hum and not pump. same result ( humming motor)... different reason. Most electricians or air conditioning or mechanical service companies could test the motor and suggest which repair is needed.
Jul 31, 2009 | Hayward Pool & Spa
Filter pump will not work
take a pliers and turn shaft with pump off if it turns, turn pump on they tend to stick from not being used
Jun 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Motor hums when turned on
Try this link for help. They suggest emailing before calling:
http://www.mypool.com/introduction.htm
Feb 24, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
309 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
