Crate amp hums when it is turned but can work at times
Hey my crate gx 130c amp will hum after sitting dormant for a while. The overdrive light goes off and there is no way to switch it from clean back. you can fix the problem by gently but solidly hitting the top of the amp head. this also fixes the overdrive problem. it will pop and go back to playing great. but the amp will hum next time you cut it on or sometimes if it vibrates to much. i need help soon because i have band practice and im no good without a strong amp. does anyone have a longer lasting solution to fix the buzzing or possibly a perminent fix???? thanks to anyone willing to help!
  • 313 Answers
Has th amp got a valve if so the valve may need replacing or might need reseating..
Posted on Jul 31, 2009
Hie, I Have got a crate tx 15 and, I have a sound problem, all time I have got a buzzzz... but there another thing too, the led for the battery recharge does'nt light and when I plug the electric...
Your symptoms would indicate the battery is defective. When a battery fails, its internal resistance goes up and they PROBABLY use this battery in place of having a separate filter capacitor so you will get hum or buzz as a result and no charging indication.
Sep 13, 2011 | Crate TX15 15W Guitar Amplifier
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Our hot tub uses a Waterway Pump. We emptied the water and refilled it with clean water. The pump now just hums... and doesn't pump. Did we do something wrong? Is there a solution. It is 220V. The...
Was the pump working prior to the cleaning or had it been sitting dormant? The motor relies on a starting circuit within it to operate. One of the components can be bad or the pump can be siezed up.
Turn off the power and remove the back cover from the motor. Try to turn the shaft by hand. Is it free to turn? If so, the problem is inside the motor. If not, look for the obstrction.
A local electric motor repair shop can help you if you find damage in the motor and/or pump.
Dec 27, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Crate gtx 65 guitar amp mains hum
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
May 19, 2009 | Lexicon LX-7 7-Channel Amplifier
05 scion xb humming noise coming from right front wheel area
Check you wheel bearings and CV joints. Check the inner CV joints also.
Dec 16, 2008 | 2005 Scion xB
337 people viewed this question
 Grubhead
Grubhead
