My VHS tape is also stuck--tapping didn't help
The tape plays 1 sec and shuts off-- same thing after I tried the tapping technique. Any hope out there???
    Problem Solver:
  • 8 Answers
Does ur vcr have a idler wheel or gears (between both spindles?) if its an idler wheel, with rubber band it commonly can go bad. their a pain. unfortunately there may not be a replacemant part. if nopt, inspect the belt for cracks or glazing. it needs friction to spin the spindle to take up the tape being played. or if ejecting, to wind the tape back in the cassete. take off the cover of vcr and watch. if the right side wheel of tape is not turning while playing, theres ur problem. the tape is instead floating every whichway. another possibility could be a belt on the right spindle. if any bands need replacing, use an ordinary rubber band ,. should work just as good
Posted on Sep 08, 2009
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
How do I play a JVC EHG tape ?
There is a VHS cartridge for a JVC EHG 30 VHSC tape. It's called a Panasonic PV-P1 Adapter, and think you can find one on eBay. I've used one before, and from what I remember, it worked pretty well. The only bad thing about it is that you need an AA battery to operate it. Well, I hoped this helped, if you still need it.
Jan 04, 2009 | JVC EHG TC-30 EHG Extra High Grade VHS-C...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Feb 25, 2008 | Emerson EWV403 VHS VCR
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
May 27, 2007 | Daewoo DV-T8DN VHS VCR
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
