My DVDRW drive suns too slow and sometimes the system tells me that the device is no t connected, it has been happened for a few months now, so I would like to change it for another drive. Does anybody can suggest any brand or make... and how to do it by myself?The model of my HP notebook is a DV4150US, If someone can help me on this one, please answer this message..Thank You!!!
Sometimes your CD/DVD drive is hidden by default if it's empty. There is a setting for that. If you have a disk in there and the drive is not showing up then you should check the power and sata or ide cables to the drive inside the case. If they are connected properly, then you need to replace the drive.
Open the Device Manager (you can do a Windows search for it if you don't know how to open it).
Look in the Network Adapters section.
Remove your Ethernet device. Right-mouse-click it and make sure it's not disabled. If it's disabled, enable it and you should be fixed.
Otherwise, click it to highlight it and press "delete" to remove it. Then right-mouse-click on "Computer" (at the top) and "scan for hardware changes." Windows *should* install the correct driver.
Otherwise you'll need to go to the HP support site on another computer, save the driver to a flash drive, external hard drive, or CD or whatever, and then install that on your computer.
You first remove that device from device manager. Then restart the pc. You may check the BIOS menu for that device for any clarification. After restart since u have removed it the OS will detect the device and install it automatically. Hope this helped.
Go to device manager under Contol panel > System browse to go at DVD/CD rom device, right click then select properties. Then click on DVD Region then select your country then hit OK.
hello i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
I have the same problem. Has anyone found a solution? I have an HP Notebook dv6700 with a Pioneer DVDRW [DVR-K17B ATA Device]. For the past few months I haven't been able to burn anything to disc. I can't find any firmware updates online. I'm not sure if I need to buy a new drive?
This is my error in report viewer for my dvdrw in laptop. dvdrw icon is hide and it can't read any disk dvd/cd. PLEASE HELP ME! THANKFUL " Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
