SOURCE: Bissell powerforce
I just got done fixing a unit with this problem. After a bit of time, dirt will build up in the lower unit and clog the vacumm tube. Symptoms: No air flow coming out of the vacuum. Motor is hot. Stuff is spitting out of the front Motor wouldnt start it had over heated. You should remover the roller and clear the clog by hand. Let the motor cool down and it should start once it had cooled down.
SOURCE: belt on this vacuum
Take off the bottom plate covering the brush roll, take out the brush roll, check it to make sure the ends turn freely, the belt goes around the end of the brush roll, then stretch it to go over the motor shaft.
SOURCE: Belt motor pulley on a bissell powerforce bagless vacuum
Yes, the motor shaft is also the pulley.
SOURCE: Bissell PowerForce Bagless Vacuum (6582)
You just have to twist hard the first time for some reason. If you hold the container with your right hand you actually have to twist the bottom half CLOCKWISE when viewed from above.
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
