Question about Whirlpool Duet GHW9150P Front Load Washer
F H problem....
I have this problem coming often in my duet washer F H can u tell me what i need to do or what is the problem.
    President:
  • 1,776 Answers
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Posted on Jul 31, 2009
    President:
  • 1,273 Answers
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component
When I have only one item or a very small amount of clothes in washer no matter whether it is set to normal or quick wash, it doesn't spin the clothes dry. I have to try to put it with a bigger load to...
If you just got it I would call the manufacture it comes with a 1 year warranty might be a board or sensor issue there are sensor's that tell how much weight is in there so it knows how fast to spin the drum thats where the power saving features come in.
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I just noticed a large pool of water under the duet washer. it is not coming from the supply lines- It only appears when the washer is running. I see it leaking down the side (just above the pedestal). ...
door boot/gasket is bad replace and problem solved.but first take the front panel below door off and make sure before you buy a door boot but if it is leaking you can tell by wipeing finger below door while running usually.
Nov 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When the washer is washing a code F20 will flash
take the top of the washer off there is a book in there that will tell you what f-20 is
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet sport whirlpool washing machine and a F then a number keeps coming up and it wont complete the cycle
What number is it. That is called a fault code and is telling you what is wrong. The numbers may be in your owners manual.
Mar 08, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet steam washer -- light for washer cleaning
Affresh
Washer Magic
Tide washer cleaner
Bleach
All in order of what is best for cleaning your washer
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer is LOCKED ! I need it UNLOCKED !!
Push and hold the button that looks like a pad lock for three seconds and a beeping sound and then it should unlock. Depending on your model. Let me know.
Apr 06, 2009 | Whirlpool Washing Machines
Whirlpool duet how to enter diagnostics
look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Baffle broke off
Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
Here is the link that will take you directly to the page:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
