Question about Maytag MMV5000 Microwave Oven
Non-working parts Our MMV 500 BBW will not work,but only parts of it. The turn table will not, the night light, thelight while the turn table is supposed to be working, but the time,timer,keypad,will. Just cannot re-heat "Those Thanksgiving Leftovers) SAD !!!
  • Anonymous Apr 23, 2008
    The turntable on my Maytag MMV5000 Microwave will not turn.
    Problem Solver:
  • 7 Answers
I would pop the back of the microwave cover off and check the fuses with a tester make sure that they are not blown. A lot of the time the connections will fry up as well. I have repaired a few microwaves in my time and usually something like that is a very simple fix.
Posted on Nov 24, 2007
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
Dec 28, 2010 | Microwave Ovens
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
Have ge sensor microwave model Je1660w
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
Whirlpool MH7140XFQ-1 light does not switch from regular to night
If there are 2 bulbs try swapping them around. If the night light works then you just need a bulb. Take the bad one with you and match it up at a parts store. Some actually have a dimmer circuit programmed in the board and that will not be a easy fix. Do you hear a click when you try to activate the night mode? If you cannot find a bulb or do not want to replace or repair the unit just disclose the non working light. I was in real estate for a couple years and a burned out bulb will not be a deal breaker as long as they are told up front.
Eric
Jun 08, 2009 | Whirlpool MH7140XF Microwave Oven
GE micro wave Spacemaker
The turntable is either plastic gear driven or uses a belt. either way, it's usually all non metallic due to the microwaves. you'll need to see if the motor that drives these are turning by removing the case. this can be EXTREMELY dangerous as the radiation from the cylstron tube. if it's a simple as a belt, the part can be replaced. good place to go is www.repairclinic.com
Be sure and rate me for this solution
Feb 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table stopped spinning
If everything on the microwave works, except the turntable, this could be a simple turntable drive motor failure. It does happen from time to time. This motor gets a workout as it runs each and every time you use the oven. I just want to reassure you that these DO wear out and should not be an indication of the quality of the oven. I've had to replace them before. The motor costs about $34 at searspartsdirect.com. That is...if your model number is correct. You will need to go to the web site and type in your COMPLETE model number. There are several Kitchen-Aid models listed with the number you provided. I managed to scroll through several of the part listings and they all seem to be consistent with identfying the motor you need as item #11 under the "Oven Cavity" heading. The part number is W10159107. This is a fairly simple repair job. You shouldn't have to uninstall the oven if it is cabinet mounted. All have to do is unplug the power source and remove the panel covering the underside of the microwave. The plastic spindle just pulls off the motor shaft. Let me know if you need further assistance. I hope this helps you.
Apr 03, 2008 | KitchenAid KCMS145J Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Maytag MMV5000 Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
