Question about Yahoo Messenger
Yahoo error 81003004
For a few days before getting the error for log in, my yahoo would constantly log in and out every 5-8 seconds and my net connection and preferences are just fine
  • 1,183 Answers
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
For pictorial refrence
http://www.theanand.com/blog/index.php/techie/81003004-yahoo-messenger-login-error/
Thanks
Proton
Posted on Jul 31, 2009
  • 724 Answers
Sometime yahoo has a glitch or two from time to time
I get error as 81003004 while login
Here is a site that show's you how to set up an HTTP Proxy server in Yahoo Messenger which should fix the problem:
and here is the site where you can find a LOT of good proxy servers to use:
http://www.proxy-list.net/fresh-proxy-lists.shtml
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Yahoo Messenger
My yahoo msgr shows error 81003004
error 81003004
what I do ??
Jul 27, 2009 | Yahoo Messenger
Error 81003004..on yahoo messenger when i try to log in
Hiya,
I'm not usually one to post links to other sites but here is a page that may be helpful.
Yahoo connection error: 81003004
I hope that helps.
Mike
Jul 21, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
Jul 10, 2009 | Yahoo Messenger
Problem in logging in yahoo messenger
[Solution # 1]
(1) Check your firewall to be sure that this port is not blocked.
(2) Ensure that another program is not using the same port number.
Type netstat in command prompt to see all active ports.
[Solution # 2]
Goto Connection Prefrences and use a http proxy. It helped!!!
[Solution # 3]
It might do this because it cant recognize the internet. Mine does this from time to time too, but I'm not sure if I get that particular error.
Try a couple things.
1. Totally close down Yahoo! and open it back up. See if that helps.
2. If you have a Wireless connection, shut your computer down and basically reboot the connection. Unplug your modem, then your router. Wait 15-30 seconds, then plug in your modem. Wait for the lights to all become solid, plug the router back in, then turn your computer on.
Sometimes a router will stop recognizing your computer. I've had it happen to me, and the odd part of it was I could still browse the net, but not use my IMs.
3. If nothing else works, uninstall and reinstall Yahoo! IM. It may just be a glitch.
[Solution # 4]
Take a look to this address : http://epayvn.info/2009/01/yahoo-messenger-error-81003004.html
Good luck
Apr 03, 2009 | Yahoo Messenger
IE is nt working , where was fire fox is wrkng. Yahoo-81003004 er
there is a small virus, what is does is, it damage your IE file and block your yahoo msg, do one thing, go to option click on tool=>internet option->click on advance then click on reset or restore default. try to use Google Chrome, it is fast and safe. you can also do the system restore in old date
Mar 20, 2009 | Yahoo Messenger
I cannot sign into yahoo messenger
The problem I have with not being able to sign into yahoo messenger is that I get an error message with number that are 81003004. It says try again...new user and sign in problems. This has been going on for many months now and I have removed yahoo from add and remove and downloaded yahoo messenger many many times. I really like yahoo and essepically my radio station I created and miss some of my friends I cannot contact any more. Please help me resolve this problem. I can sign into my home page with correct password with no problem but not yahoo messenger. Like I said the error message I get is 81003004 that is showing up on my yahoo messenger IM log in. Thank You for your assistance. chickiechackey@yahoo.com
Mar 12, 2009 | Computers & Internet
Messenger cannot connect
81003004 and 81003005 are quite similar errors and increasingly common these days with Y! 9.0 being so popular. I suffered the same error and I'm finding more and more that the only similarity between people who've had this error would be that all of them had the Microsoft .NET 2.0 Framework installed. I don't know why or if this is a cause but for me this happened each time I re-installed Visual Studio which requires 2.0. On XP one of the AU downloads is 2.0 as well so anyone upgrading to XP would eventually run into this error. Mine happens to be working now, thank God, but even Y! engineers know of no fix for this problem yet. They'll instruct you to contact your device manufacturer. In the mean time if it's worth it you may consider backing up your data and keeping a log of your installed programs as I do. Use maybe a USB drive or similar memory device and label folders 1-? and in those folders place your files such as browser bookmarks, etc. Then in a notepad document just write down the line 1-? what location to put the given files in. Makes a re-install of an OS very simple. You may also try an uninstall of the .NET Framework just to see if that's your problem. :)
Jan 19, 2009 | Yahoo Messenger
81003004
Go open Internet Explorer and go in the File menu and uncheck at the bottom the Work Offline option. Then go to a site using IE. Close IE. Open Yahoo Messenger and log in.
Nov 13, 2008 | Yahoo Messenger
Yahoo Messenger Logo
288 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
