Question about Novelty Lava Desk Lamp
Lava Lamp is new, not working, spring loose on bottom, no blobs
Hi, We received as gift, after four hours the lamp is cloudy, oil is not in motion, blob at top and some in middle. I notice a spring seems to float around near the bottom...doesn't seem to be attached. Can you assist please? Thanks. jf
    President:
  • 1,273 Answers
The lamp is made of wax and alcohol. Try inverting the bottle several times. The aim is to get the wax to fall to the bottom. Try shaking it, especially when the fluid is warm. This may help break the wax up to where it can begin cycling on its own.....careful, though, you don't want to burn your hand. I have done this several times, and it works!
Best regards, --W/D--
Posted on Jul 31, 2009
VORTEX LAVA LAMP STOPPED WORKING
lamps run on a small 25W bulb
Should be able to replace with little problems
May 21, 2014 | Home
My tornado lava lamp doesn't work. A little plastic piece just bounces around on the bottom.
It's difficult to say based on your limited description. A lava lamp is a first of all, a lamp. Does the incandescent lamp light up? If not, replace it (it's the heat source which creates the swirling action in the attached "lava" globe). As for the plastic piece, perhaps it's part of the lamp-holder socket that broke off due to heat. Perhaps part of the switch.
In any case, the light light bulb probably burnt out. Believe it a standard 40 watt bulb, but be absolutely certain to check before replacing as you do not want to put a bulb with a higher wattage in there due to the confined space inside the lamp.
Apr 13, 2014 | Novelty Lava Desk Lamp
My projector will go off after 5-10 minutes, started with longer periods like 30mins or more... Sometimes it worked without any problems. It has a new lamp on it and Im not sure what can be the problem?...
hi,
First of all check the lamp hour of your projector. Just reset it and try again. for resetting the lamp hour do the following.
1.Switch on the projector
2.select menu and the select lamp setting
3. In the lamp setting menu select lamp Reset and execute the same
After doing this if the problem remains then you have to check two things. first you have to check the lamp cooling fan of your projector. If the lamp cooling fan of your projector is faulty or it runs in a low speed this problem can occur. Another possibility is the faulty temperature sensor. you have to check the temperature sensor near the lamp. normally a senor with two wire fitted on the lamp Cage.
if fan is suspected then remove the fan and try to oil the fan and the re fix it and try again. for oiling the fan watch the following video.
The video is for oiling a pc fan you can follow the same to oil the lamp cooling fan
ok
Apr 20, 2011 | ViewSonic PJ406D Multimedia Projector
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
Lava Lamp is new, only turned on 3 times. Larger in size. Spring is attached to blob on the bottom. Should I leave it on to heat up and hope the spring falls back down?
The coil spring in the bottom helps to spread the heat through the blob. Once it has been displaced it will take quite some time for the blob to liquify enough for the coil to be able to settle back to the bottom. It may take as long as two hours for an extra-large one to liquify. You will have to be very patient, but turn the lamp on and LEAVE IT ALONE.
Aug 09, 2010 | Novelty Lava Desk Lamp
Lava lamp problems
If it has been shaken or tuned over, then the liquid has mixed with the wax, which is why is doesn't circulate. You may be able to fix this by turning the lamp on until the lava starts to break up, then turning if off and letting it cool. Repeat this up to six times to get the liquid and the wax to separate. However, it may be irreversible.
Mar 07, 2010 | Toys
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Its all cloudy after being knocked over my lava lamp
This explains everything:
http://www.lavalamp.com/resources/faq/
Please vote for my solution if it helps.
Jan 08, 2010 | Novelty Lava Desk Lamp
Dell 3200mp
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @ussmillerco@yahoo.com and let me know. Good luck thx sean
Nov 21, 2008 | Dell 3200MP Multimedia Projector
Home Logo
2,267 people viewed this question
Top Novelty Home Experts
Jax Planet
Jax Planet
robert
Are you a Novelty Home Expert? Answer questions, earn points and help others
