Question about Kenmore HE2 Plus Front Load Washer
Washer lights up as if responding but does not start up when start is pressed. Is there a reset button, I have looked, but unable to find/
    Problem Solver:
  • 4 Answers
Just tell us if there is a way to reset it? I know mine did that one time and I had to press a couple of buttons in sequence and it reset it but cant remember which ones they were...my is a 2006 model
Posted on May 03, 2010
  • 98 Answers
How old is your machine? Sometimes parts just wear out, and they need to be replaced...check to see if the timer disc needs to be replace, or curcuit board if it is computerized.
Posted on Jul 31, 2009
Dish washer cycle wont start
will it not start because of power?
or buttons light up but no start? what happens when you press start? Light up? If no light, that' where the problem is. Try other buttons if they respond differently. Lastly are you sure you close the door securely?
Aug 07, 2013 | Bosch Dishwashers
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
Wash cycle stuck
You can attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes resetting it is all that is required to correct momentary program glitches. If the problem reoccurs following a CCU reset, then you have a legitimate problem. Let me know if you still experience problems. I hope this helps you.
Jul 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Failed to complete cycle.
Probably blockage in pump or sump hose from drum to pump.
Remove and clean.
Nov 22, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Dcp115c brother unable to clean
BROTHER INTERNATIONAL
ATTENTION: CoDEC0012 "JOHN" email oblacks_pit@yahoo.com
UNABLE TO CLEAN?
1. TO ENTER MAINTENANCE MODE: PRESS MENU, MONO START, 4X ON ARROW UP (WITHIN 2 MINS)
2. USING ARROW UP BUTTON LOOK FOR THE FOLLOWING
a> 8 then press SET
b> 0 then press SET
3. USING MONO START, JUST PRESS IT UNTILL THE WORD "PURGE XXXXX" COMES PUT.
4. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING: "FLUSH"
A> 2 THEN PRESS SET
B> 7 THEN PRESS SET
C> 8 THEN PRESS SET
D> 3 THEN PRESS SET
THIS IS TO RESET THE PURGE COUNTER
5. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING
A> 0 THEN PRESS SET
B> 1 THEN PRESS SET (TO RESET UNIT)
C> 9 THEN PRESS SET
D> 9 THEN PRESS SET (TO EXIT MAINTENANCE MODE)
THAT'S ALL FOLKS JOHN
Jul 24, 2008 | Office Equipment & Supplies
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
May 23, 2008 | GE WSXH208A Front Load Washer
BIJ 2800 unable to print as error "-00D4-c3f9 LIB MICCI.DL212" error appears
HP All-in-One Products - Performing a Partial Reset of the All-in-One Introduction There are times when a partial reset may be required to restore the all-in-one to proper operation. A partial reset does the following:
  • Reset the user settings to the factory defaults.
  • Reset the language and country/region settings on some models.
Performing a partial reset Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
      NOTE: If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  3. Press and hold the button combination for your all-in-one.
  4. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Product family/model
Button press
HP PSC 2500 series
Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # .
Apr 21, 2008 | HP PSC 2355 All-In-One InkJet Printer
Kenmore Elite HE4t Washer - "Control Locked"
I had the same problem. If you will hold the "Drain & Spin button" in for approximately 4 to 5 seconds it unlocks the " Control Locked" issue.
Dec 18, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
671 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
