Question about Sanyo DP32746 32 in. LCD Television
I have a Sanyo LCD-32CA9S. Turns off after 10 minutes
I have a Sanyo LCD-32CA9S. When I turn it on I get what looks like it starts up in a sleep mode. On the screen I see Off 00:10 and after 10 minutes the TV turns itself off.
Hai sir iam bittu ihave lcd 32ca9s sanyo that is repairing now problem is audio is coming sreen is not coming how 2 repair that plz tell me
Posted on Apr 30, 2014
  • 560 Answers
Tru using your remote to access the factory reset mode to default. It might be hard to find, but it should be listed in your tools or settings options somewhere. Also, you can unplug the set for 5 minutes and then plug it in again. This resets the computer in several models. It's like a hard reboot.
Posted on Jul 31, 2009
How do u unlock how sanyo lcd-32ca9s tv without the remote
why did you put a lock on it . and remotes do not have legs to get up and hide from us .universal replacements can be purchased every day of the week for under 20.00
Jan 17, 2016 | Sanyo Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Sanyo DP32746 32 in. LCD Television
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Factory reset
in thid you have reset you tv with help of tv remote . this syestem is used because while seeing at night some oerson sleeps. so he set timer after which the tv gets turned off. to solve this you have to go in menu and you to search for a tinner or sleep option it can be directly on your tvv remote
Jan 30, 2010 | Sanyo DS24425 24" TV
Tv turns off after 45 minutes
look in your menu and see if you have sleep on or there could be a botton on your remote that says sleep and could be on.
Jan 03, 2010 | Dell W3201C 32 in. LCD Television
Model26LB30QD turns itself off not in sleep mode.
There was a glitch in the electrical system. There was nothing we or anyone else could do. We returned the televion.
Jan 09, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Sanyo LCD 32CA9S
hw do i get child lock off without remote
Oct 07, 2008 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sanyo DP32746 32 in. LCD Television Logo
664 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
