Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker i have a kitchenaid superbra that makes ice sometimes. when it first stopped working i tried turning the fingers that push the ice out by hand. know it works about 5% of the time. when it does it stops half way thru the cycle. i tried helping it along and now it dont work at all. please help
  • 447 Answers
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Posted on Nov 24, 2007
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have a Kitchen Aid KSRG25FKSS17 side by side refrigerator and ther ice maker stopped working. I got the ice out of the tray and it filled up with water and the fingers cycled around but will not push the...
Good day,
When ice cubes are formed, a thermostat embedded in the ice maker closes, and then starts a motor that cycles the rakes, ejecting the cubes.
When the fingers of the rake hit the frozen cubes, the motor stalls.
However, there is an electric heater embedded in the bottom of the ice maker that at the same time is heating the well of the ice maker, freeing them up and allowing them to be discharged.
You should remove the ice maker, to see if there is a foreign object that fell into the well, preventing the cycle from continuing. If so, remove the item and reinstall the ice maker.
More commonly, the motor has weakened or the heater has failed. In either case, replacing the ice maker is your only option. There are in some cases a repair possible, but it is not cost effective.
Sep 21, 2010 | KitchenAid (KSRD22FKST) Side by Side...
We have a KitchenAid side by side Refrigerator Model KSRG22FKWH15 with style 2 ice maker. Have water but ice not being made. Have checked all normal reasons for not making ice. How do I remove ice maker...
try this:
1. Remove the bucket from the door to get some room.
2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
4. Remove the screw in the right rear bottom side of the ice maker.
5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
6. On the left track the should be a tab toward the bottom which you need to push up.
7. Push up tab and start working the ice maker towards you pulling it out of the track.
8. Careful with the electrical harness in the back as you're pulling out.
9. Disconnect the electrical plug by lifting the clip on the plug.
10. Remove the side cover on the side module by pulling off.
11. Remove the bottom shield by removing the 3 screws on the bottom.
12. To install reverse the order as it came out.
Apr 02, 2010 | KitchenAid (KSRD22FKST) Side by Side...
No ice from fridge
the water valve has two parts ( ice side and foutain side ) ice side could be bad . the tube in freezer that feeds the water could be frozen . and the ice mker itself may be bad . mm
Nov 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not getting water. Everything else seems to work fine. I can put water manually into the ice maker and get ice. But no water from the line. It is a KSRS251 superbra side by side Kitchenaid model.
You will have to remove the icemaker and look inside the water fill tube at the rear wall of the freezer.
The water line may be frozen closed.
If so,take a hair dryer and thaw it out.
This manual will explain other test to complete.$FILE/4322658A.pdf
Nov 09, 2009 | KitchenAid KSRS25IL Side by Side...
The ice maker stopped working, gradually over a 3 day period.
It sounds like your harvesting motor failed. If you feel comfortable working on it, you can pull the ice maker out and remove the harvest motor and have it replaced. If you don't feel comfortable pulling out the harvest motor, pull the ice maker and replace the whole unit. They are a little tricky getting them out but if you take your time and don't rush, it is a doable fix for the typical do it yourselfer
Jan 11, 2018 | KitchenAid KSRB25FRBX Aluminium Side by...
Kitchenaid superbra 24 oven
select clean on the control panel and set stop time then push start
Jan 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
197 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
