SOURCE: DOOR PROBLEM
I am not sure about your oven model. I had a similar problem in my oven. The hinges are riveted to the oven and can be fixed. First remove the oven door - normally the door slides on to two prongs on either side and is screwed down. Once the door is removed check the mechanism that holds the two prongs to the oven body. Mine were held with stainless steel rivets that had worn out and became wobbly. Cut the rivets and replace them with new ones. You can get a rivet driver and the stainless steel rivets for under $20 at Home Depot. Hope this works for you.
SOURCE: How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
SOURCE: Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
SOURCE: PROB WITH DIPLOMAT 620 DOOR- HINGES BROKE- DOOR
How can I replace the hinges of a Frigidaire FGB24T3A Gas Single Oven ?
