Question about GE 24GP653 24" TV
Remote control how do i program a suddenlink remote to work with the tv
0 characters
1 Points
I have a universal control and i don't have the codes for it to work the tv
    Remote Control Code List
    Jumbo Universal Remote Control ยท 8 Device ... Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote. TV Codes ... JVC, 013,054,055,060,065,067,089.โ€ŽGuide to Programming the ... - โ€ŽDownload the Manual - โ€Ž8 Device Learning Jumbo ...
    What is the universal control remote code for a JVC television? > Technology > Television & Video
    JVC universal codes can also be found on the instruction sheet or manual guide that comes with the remote control or television set. If these universal codes do ...
    JVC Remote Codes
    A list of TV, HDTV, DVD, Receiver, Audio, Amplifier and and VCR remote codes forJVC. images for codes for universal remote control jvc
Jan 03, 2016 | JVC AV-32D305 32" TV
"Model KV-36FS210" "Sony TV" Suddenlink service issue
Hi - My name is Ashley, and I'm with Suddenlink. I'm sorry to hear that you're experiencing issues with your cable TV service. If there's anything I can do to help, please feel free to contact me directly at ashley-AT-suddenlink-DOT-com. Thank you.
Apr 26, 2014 | Standard (CRT) Televisions
I have a Durabrand Univeral there anyway to sync it witha Suddenlink Cable box?
Hi- My name is Shannon and I am with Suddenlink. You can find remote control codes on our self-help site here: Thanks!
Feb 07, 2013 | Standard (CRT) Televisions
Sanyo DS31590 no remotes will work, will not turn on power or volume but changes channels
If you can control the TV by using its front panel controls, and only remote control is not working, the fault may be either to its remote control handset or to the remote sensor inside. The remote sensor is a small component, having only three solder terminals and will look like this. 7_12_2012_12_53_47_pm.jpg7_12_2012_12_54_01_pm.jpg
This is the component inside the TV which senses the infrared rays emitted by the remote control, and convert it to digital signals, and send to the microcomputer section circuit to process. This component can be located just behind the infrared remote window at the front panel of the TV. You have to open the TV to access it, and to replace it. Just check your remote for its infrared emission, before going further. Just get more details about how to check a remote control from this site named 'Electro-help'. Pull up older posts there. Just check this link, and locate the site named above.
Jul 12, 2012 | Sanyo DS25390 TV
I bought a oneforall universal remote but need a code for a supersonic 1380
If you are a user of AT&T Uverse remote, your technician might have possibly programmed your Sanyo TV remote before leaving.
If your remote is not programmed you can easily program it by following steps which will be mentioned in the user guide, these include:
  • You must know the four digit code for AT&T Uverse which might have been given to you at the time of TV set up.
  • The remote control codes for Sanyo TV AVM - 1337U are 1045, 4062, 1095, and 1380.
There are different methods to make your Sanyo TV remote work. For example, if you have a black remote, press the zoom button which will be on the right hand corner of your TV. Then you will have to press fast forward for two seconds or till the time the TV shuts down automatically. Then once again switch on the TV and press zoom, your remote will start working once again.
In case you have a silver colored remote control, enter code 922, you will be guided to a menu. You must select RCA. IF code 922 does not work for you, enter code 1041.
  • Any of the codes mentioned in your user guide book will definitely work. Once the code is accepted by the TV, you can program it easily and set the channels of your choice.
  • While setting programs you can program it either the manual programming method or the code search method.
  • Device codes assigned to the TV will again be mentioned in the user guide booklet.
  • The Uverse remote control is a universal remote control which is user friendly.
  • These programmed remotes are configured to work with other audio and video devices too. Uverse also offers other services such as high speed Internet, cable TV service, home phone, etc. It's rated as the best service provider in the market.
Audi Air Intakes
Jun 07, 2012 | GE Standard (CRT) Televisions
I receieved a SYLVANIA 6432GG TV with a remote. The remote control doesn't work. The previous owner had programmed a Comcast remote control to use on the TV. I don't know how to reprogram t
GOOGLE THE MODEL NUMBER OF THE SET (IF ORIGINAL REMOTE) WITH "manual" which would get the owner manual to do this.
Each set is different in this process.
Apr 08, 2012 | Sylvania 6432GG 32" TV
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Lost remote and rca universal remote no can be programed
I used the remote control code of "69" for Thompson which makes GE & RCA according to another post. This worked to program the remote of my GO Video DVD-VCR for the TV
Dec 29, 2007 | Proscan PS27113 TV
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Standard (CRT) Televisions
GE 24GP653 24" TV Logo
335 people viewed this question
Top GE Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a GE Standard (CRT) Television Expert? Answer questions, earn points and help others
