SOURCE: television when turned on: light goes to green
If the Red Light Blinks twice and goes out, the TV is in Protection Mode. There are 6 voltage outputs to the lamps around the screen. If one of those outputs is missing the TV will sense that there's a problem and refuse to turn on. The predominant failure in this model are the output transformers on the Inverter board. A properly trained technician can measure the windings on each transformer and look for an open circuit, if one is found, replace that Transformer. i was given one of these sets from a friend and I replaced an output transformer ($11 w/shipping) and I now have a fully functional TV/DVD Combo. Also verify that all of the connecting cables internally are properly seated, there have been reports or the ribbon cables from the Power supply board to the main board above it not being fully inserted and it also prevented the TV from turning on. A word of caution. There are VERY High Voltages on the inverter circuit board, only persons with proper training and knowledge should attempt this repair.
SOURCE: red light comes on /
The power board has a fault or it is sensing a fault from another circuit and shutting down. If you have an electronics background and some test equipment I can walk you through what to test. Or you can take it to your local TV service center.
http://tvtechwork.webs.com/
SOURCE: won't charge. Red light come on for about
Hi Peter,
I'm sorry to hear you're having difficulties with your DC16. From what you've described, it sounds as if the filter may not be correctly fitted - please follow the steps shown in our online support guide to resolve this:
http://www.dyson.co.uk/support/help.asp?article=1519&product=DC16-SY-STD
If you're still having issues after trying this, it's probably best if you get in touch with us directly, so one of our Helpline experts can run through some troubleshooting over the phone. You can call free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
SOURCE: My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
SOURCE: Dolce gusto red light goes out green light does not come on
Hi, my mom's dolce gusto did something similar. I took a look at it closely at every possible part not working and found the power button stucked in pushed position. I could have sent it to a service center but in Mexico that will take for ever and could be more expensive than buying a new one. So i jussy
