Question about Zanussi ZWC1300W Front Load Washer
Frigidair front loading washer made loud thumping noise and now it wobbles on final spin. does great until it spins fast. looking through the door, it seems to rotate kind of out of round
  • 24 Answers
Check springs and suspension legs.
Posted on Aug 05, 2009
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
My washer mad three loud thumps and then would not spin at all. It will pump the water out but will not spin. Do you think it is the belt. Thanks helyn
The belt might have slipped off the pulley. But when you mention that you heard loud thumps before it stopped spinning is a sign that something else might have gone wrong with your machine. With the washer turned off, turn the wash drum by hand and listen for any noises. It should turn quietly without any kind of thumping noises. Also look how the drum turns. It should turn smoothly and not wobble as it turns. If it wobbles or makes thumpiing noises, it means that the support arms are broken.
Reparing the support arms is an expensive repair, unless it is still under warranty, it not worth fixing. Get a few estimates before deciding to repair or replace it.
Feb 08, 2011 | Frigidaire ATF6000ES Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Dec 26, 2008 | Danby DWM5500W Front Load Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Loud thumping while spinning
    my friend had this happen,apparrently a bearing was leaking then finally broke!
    Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
    Zanussi ZWC1300W Front Load Washer Logo
    91 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Chris Hall
    Chris Hall
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
