SOURCE: My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
SOURCE: hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Check whether the "print preview" on the screen shows blank too...
Make sure the document you are printing doesn't have blank pages. You may think that it might be one page, it might be two. Somehow you may have inserted a blank page or two.
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from this product or the computer. get more information from here....... http://answers.yahoo.com/question/index?qid=20100905152100AAMq5Iv
SOURCE: Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
SOURCE: HP 4500 Printer blank pages
Every so often? Sometimes if the printer is set to print on Legal sized paper (8.5" x 14") it will take an extra blank sheet if the sheet sizes are letter. This may cause every other page to be picked up and drawn through the printer as a non printed page.
Hi Moses Oghor Edwin, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Has it got a toner in the toner cartridge ?
