Question about Hoover Vacuums
How to change motor brushes on hoover otsein NEXT 3650T/1-37 top loader
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: hoover h3030
In thi picture, did you replace #20? It is what drives the brushes.
Posted on Mar 21, 2008
  • 11 Answers
SOURCE: Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Posted on Oct 29, 2008
  • 57 Answers
SOURCE: Hoover Savvy U8174-900, replacement circuit board LED/Brush Motor
clear1x1.gif Hoover Switch & Circuit Board with Handle for Hoover Savy & Bagless
Follow this link to USAVACUUM.COM
www.usavacuum.com/category-s/63.htm
Posted on Feb 21, 2010
I have a Upright Hoover Elite. Can't get belt back on right.
The belt loops over the motor shaft and the brush roller. Verify that the arrows on the end caps of the brush roller are facing DOWN or you will be doing the job over again. Start with the motor shaft and stretch the belt to allow the brush roller to seat. A new belt can require a strong pull on the brush roller to get it seated.
Nov 16, 2016 | Hoover Vacuums
Brushes not rotatine on hoover f7425-900
Check to make sure that the foam filter inside the recovery tank lid has at least a 1/4 inch gap from the top. Other then that, the turbine is what turns the brushes, either the shaft on the top of he brush block broke off, or the turbine is stuck. Sometimes you can take th turbine apart and clean out the components, must times it is better to just replace it .
Goodluck..
May 17, 2008 | Hoover Vacuums
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Aug 10, 2008 | Hoover Vacuums
Belt Replacement
Take the bottom plate off, the brush roll and belt are there. the belt goes around the brush roll and hooks to the motor shaft. If you can't get to the motor shaft, then you will nee to remove the top cover also.
May 12, 2008 | Vacuums
Need to change belt on hoover futura
You didn't say model number, but remove the bottom plate to get to the brush roll, if you can see the motor shaft, the belt goes from the brush roll to the motor shaft. If you can't see it, then remove the top cover to get to it.
Apr 19, 2008 | Vacuums
Hoover u5209-906 upright
1. You have to lay it on its front so you can unscrew the two screws in the underside (these are on the plastic panel covering the brush). There are also two holes for you to use a screwdriver in right next to each screwhole. Lever the plastic tabs in the direction indicated next to the holes (I think it is towards the motor). This case should then click up and away N.B. There are 3 tabs fixed into the cover on the front edge of the vacuum head. Be sure you don't snap these off.
2. You then need to use the foot pedal at the back of the vacuum to lay it flat and using a flat bladed screwdriver lever the top cover of the head away from the frame on the two back side corners and across the front of the head. The top case should now be able to come off.
3. The belt should now be able to slip off the motor spindle and off the brush.
Repeat the procedure in reverse once the new belt is on.
Cheers.
Apr 13, 2008 | Vacuums
Need to change the belt on my hoover 5403-900
Take off the bottom plate covering the brush roll, you may have to tak off the top cover to reach the motor shaft if you can't see it from the bottom. The belt goes over the motor shaft and then over the brush roll, the belt is stretched to connect.
Mar 26, 2008 | Vacuums
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Vacuums Logo
23 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
