Question about Cycling
ReAssemble front wheel . Can't get front wheel over the brake pads of the bicycle
  • 29 Answers
You have two choices:
1. Find how the brakes release so you can spread the pads enough the get the tire between 'em. Sometimes there's a lever on the brake itself, sometimes you need to pull a cable guide out of a slot. . .usually there's a way to release the tension to open 'em up.
2. Let enough air out of the tire to fit the wheel back in, then pump it
back up.
The easy way is to put the wheel in, then pump up the tire.
Posted on Aug 04, 2009
  • 69 Answers
Need to loosen the cable so the brake will spread apart
Posted on Jul 31, 2009
Having trouble attaching front wheel. Owners manual or instruction sheet misplaced
How to install quick release front wheel on bicycle - YouTube
? 0:58
https://www.youtube.com/watch?v=xFx7UXyjW4Y
Dec 11, 2011 - Uploaded by Bicycles Online
When I went to reinstall my wheel my brake pads were stuck together and I don't know how to get them apart ...
How To Remove The Front Wheel of a Bicycle - YouTube
? 7:31
https://www.youtube.com/watch?v=BNwa0lONtbc
Jun 30, 2012 - Uploaded by cjhoyle
This is a quick tutorial showing how to remove the front wheel of a bike. ... Getting the lightly tightened other nut off shouldn't be aproblem.
Removing and installing your bicycle wheels - YouTube
? 4:06
https://www.youtube.com/watch?v=QslgCn9QX5I
Dec 25, 2015 | Cycling
1999 f-250 Xlt 2 wd abs light on right brakes sometimes seem slow releasing brakes
You might have a pinched or plugged brake line leading to that wheel, or an ABS malfunction in that wheel's circuit could be giving you trouble.
Aug 07, 2014 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
What causes the brakes to squeak loudly, and how do I fix them?
This a common problem. What I have found that works well is to change the angle at which the brake pads contact the wheel of the rim. Keep in mind that the top of the wheel moves forward (relative to the brakes), and you want to adjust them so that the brakes don't first contact the wheel with their leading edge. That is, you want the end of the brake pad that is toward the front of the bike to contact the wheel first. You might be able to bend the brakes very slightly, or you can put a little shim (a thin washer works well) between the brake pads and the lever to which they are attached - you will have to loosen the nut that attaches the brake pad, and slip the shim under it on the side nearest the front of the bike.
Jul 04, 2011 | Cycling
Brakes need to be tighten
The wound steel cable that connects your brake lever to the brake pads can be adjusted via a screw or nut at the top of the brake pad assembly. Simply loosen the assembly and gently tug the wire end toward the front of the bike tire to tighten brake grip; tug it backward to loosen. Tighten the screw partially to hold the cable in place, test the brakes with the brake lever, and adjust again if necessary before fully tightening. It may help to put the bike on a stand or hold it so that you can spin the wheel, check that the brakes are adjusted so that the pads do not rub the wheel. You can do the same thing with the rear brakes. You will need a small tool to loosen and tighten the brake pad assembly; your household toolbox should have something :)
While you are adjusting the brake tension you should also check the brake pads for signs of wear. If your bicycle brakes squeal, show uneven wear or are perfectly smooth, go to a shop and get a new set! Regular brake maintenance is very important for bike safety.
May 19, 2011 | Cycling
When apply brake rear brakes sounds ,squeal.
You have to "toe in" the brake pads so that that don't just sit flat on the wheel rim. The front of the brake pad should contact the wheel first, that way, the brake pad doesn't cause a vibration to occur.
Jan 08, 2011 | Cycling
How sohuld I keep my bikes clean?
Bike maintenance: how to clean your bike. When it come to how to take care of your bike - keeping it clean is the number one most important tip. If you ride your bike regulary, inevitably it is going to get dirty. Dirt,sand and mud will cause parts and elements to wear out prematurely. For example, bicycle break pads should be replaced regulary, as they rub against the wheel and sustain wear.However,any excess dirt caught between the wheel rim and the brake pad will result in prematurely worn pads,rim damage,and compromised brake function. Make it a point to wash your bike after long rides,or as frequently as you are able . Wash the bicycle with worm soapy water,rags and brushes that will enable you to scrub the dirt,and scum from the front and rear derailers,cabels,wheel rims and brakes, chain and sprockets.Specialized chain scrubbing tools are sold by many bicycle retailers. Most cyclists recommend using green or all natural soaps, particulary if you plan to wash your bike outdoors. When washing, avoid getting water into elements such as gear shift levers,wheel bearings or crank bearings.
Dec 21, 2010 | Cycling
Loud noise comes from rear brake when braking
When you squeeze the brakes, the rubber pad should NOT be flat against the rim. Instead, the FRONT of the rubber pad should be a bit closer to the rim than the back part of the pad (about 1 mm or 1/16th inch).
Also, you can try to put fine sandpaper (150 grit) between the rim and brake pad, with the rough part facing the brake. Squeeze the brakes lightly and move the wheel a small amount to scuff the brake pad to remove any dirt on it.
Dec 30, 2009 | Clark 's Bicycle Brake Shoes Rim Pad...
I took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Oct 02, 2009 | Cycling
Cycling Logo
133 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
