The washer pauses during cycle and i have to resume washing for it to finish the load. Do you have any idea why?
You have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Have a problem with my machine that it wont go to the rinse cycle. The timer keeps going and the washing stops doing everything all together. I put a new controller board on it and still the samething. What can I do to fix it?
I didnt have any tech support to help me but I was able to remove the tube that goes to the drain pump and it was clogged with a bobby pin. pulled it out and it works fine know. But I did get part of my answer from here at the "It wont Spin or Pump". So Thank you for the feed back from others problems. That was how I figured it out. It save me some money from trial and error.
Water not heating, check to see put on 90 wash. if washing machine dose not heat it will not move on.element may be faulty or wire off. Ire bye
had the same problem removed front panel 3 screws got bucket removed filter along with 1.23 in change ,rocks ,screws ,ect put machine back together working just like the day it was deliverd
we have the same problem it will stay on door locked and stuck on the last rinse which is 1 and know it won't drain the water I've had the washer for 2years and I hate it from day 1.
We had the same problem and cleaning the filter worked. We found four coins, five baby socks, an inside of a pen, and lots of gunk!
thanks for the solution it worked like a dream and im glad im not the only one with the problem.
