Question about Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
I have this in my rv bedroom.The unit has thermostat control knob on unit.When it reaches temperature and the compressor turns off it will try to restart within 1 minute.After 3 or 4 times the 20 a breaker trips.Can I hook a wall thermostat up to this unit.This unit has 3 fan speeds ,3 ac fan speeds and manual thermostat control knob.My dealer put a 30 a braker in and said dometic said thats the only way to fix short cycling.I don't but that at all.This unit is new and still under warranty.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Posted on Aug 01, 2009
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
We turned the ac unit control knob in between the high cool and low cool, which turned off the ac unit, but messed it up where it shorts the circuit breaker when we try to turn it back on. What did we do?
YOU MIGHT OF JUST SHORT CYCLED IT . ALL AC UNITS NEED ABOUT 3-5 MIN TO EQUALIZE PRESURE ON COMPRESSOR BEFORE RE STARTING  . IF THIS IS RV AC MAKE SURE YOU HAVE WELDING TYPE EXTENSION CORD
Apr 22, 2010 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
A/C starts, goes immediately to heat
Unfortunately, your rear unit is calling for heat. If you put the rear unit on heat pump mode, does it then cool?
moz-screenshot-2.jpgmoz-screenshot-3.jpgThe reversing valve is energized in the cool mode of these AC's. So there is no real way to bypass it. I would check the thermostat and the control board in the unit to make sure that the switches are set correctly.
In the service manual section of the dometic/Rooftop RV Air Conditioner section. I have posted service manuals for the Heat Pump and the Comfort Control.
Hope this helps,
Jeff
Rate me please.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
AC comes on and stays on until you move the setting up to around 90. At times the unit will not cut off no matter what setting you choose. If it cuts off at 90 after manually moving it there, you only have...
If the house is actually cooling, but the thermostat thinks in 90 degrees in there, you definitely need a new thermostat. If the house is actually 90 degrees, the AC SHOULD cycle on and stay on till it reaches the preset temperature. Since it doesn't make sense that you would complain about the AC cycling on at 90 degrees, I can only conclude that you have a faulty thermostat.
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
13500 dometic ac for rv with anilog thermostat
My Unit is only about 5 years old; but it's working great now. I spoke to a man at an RV service department, he suggest replacing the thermostate and Jay box, which is the box inside my roof unit, accessable when I remove the filter. When I replaced the thermostate nothing changed, but the Jay box did the trick. The Jay Box came with a new thermostate anyway, and cost around $80. Good Luck
Feb 18, 2009 | Dometic Rooftop RV Air Conditioner
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
446 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
