Question about Garden
Craftsman weedwacker 358.791070 suddenly stopped
My Craftsman weedwacker 358.791070 suddenly stopped. The fuel tank was still more than half full. I let it cool and tried to pull the starter rope. The starter rope does not pull out more than 3'' , so I cannot start it. I used this machine only 3 - 4 times when my landscaping guy could not do the lawn. Any idea what caused it and how can I fix it, if it is fixable?
  • 162 Answers
Could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Posted on Jul 31, 2009
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
I have a lil hoe tiller and I need a new fuel line that goes into the tank. Where can I find one.
You could try lowes or home depot...however when I work on law equipment such as the hoe tiller or weedwackers, I use tubing for fish tank pumps...you can purchase at supermarket or pet store in like 5-10ft lengths and you can cut it to the size you need. Only cost a few bucks and works like a charm. It is the clear silicone tubing...also just an FYI if your pull started cord ever breaks, you can use parachute cord sold at any sporting good store that replaces the pull starter rope and will never snap again.
Sep 05, 2016 | Garden
How to fix the starting rope on a craftsman weed *******
is the pull rope in front of the engine ???
yes ???
you dont wanna know
Aug 05, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Fuel want pull into bulb on my craftsman 27cc weedwacker #711200
There are 2 fuel lines going into the back of the primer bulb. One line goes from the back of the bulb into the fuel tank, and the other goes from the back of the bulb into the carburetor. I believe that the line that goes into the fuel tank has disconnected from the back of the bulb. You will need to remove the bulb, find the line that dropped off of the bulb and into the tank, and reconnect the line to the back of the bulb.
Jul 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
My craftsman weedwacker starts on full choke then at half choke it still runs but i have to really rev it and then when i move choke to off it dies
This is fuel starvation, start with easy things first, replace the fuel filter in the tank, check the condition of the fuel hoses up to the carb for splits, cracks or leakage, replace if required
Jul 03, 2012 | Garden
Craftsman weedeater will not start
The most probable problem is no fuel delivery to the engine.
1. Check/replace the fuel in-tank filter, you should be able to easily blow through it once removed. The primer bulb will sink down and not return quickly if the filter is bad. Fuel will not return to the tank via the return line if the fuel filter doesn't allow fuel to be pulled in.
2. If fuel is returning to the fuel tank when the primer is pushed then your problem is inside the carb.
3. To verify this put a small quantity of gas in the lid of a water bottle (half full). And pour it into the carb throat. Replace the air filter to prevent a backfire from shooting flames out. Try to start the weedwacker. If it runs and then dies the problem is inside the carb.
4. If you are really good at working on things with small parts you can clean out the carb and replace all of the gaskets to solve the problem. If this isn't for you then you should take it to a lawn shop and have them clean the carb and replace the gaskets.
NOTE: Replacing the gaskets is very important because the gaskets get stiff and the fuel pump action of one of the gaskets is reduced or stopped.
Hope this helps, Karl
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Starter rope trouble
it might be vapor lock, try taking the spark plug out and giving it a pull
Oct 18, 2008 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Garden Logo
473 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
