Lg washer shows up side down F E code
Washer runs until spin cycle and stops and shows code. I unplug unit and let sit for a while and restart and unit somettimes work or will shut down and show same code. Is this same error as LE code
    President:
  • 1,776 Answers
No, this is not the same as the LE code. The FE code indicates an overflow error or condition. The things to check out would be the drain and the drain line to make sure there are no kinks in it. The drain hose can get clogged with sludge and sometimes a hot wash with a 1/2 cup of vinegar will clean out the sludge. If that doesn't work, I would take a look at the pump to make sure it is not clogged with anything and that the pump impellers are good. Take a flashlight and look into the suction port of the pump. Look for any broken or missing impeller blades. If any are broken or missing or if the impeller will not move freely, the pump would need to be replaced. Hope this helped and best wishes.
Posted on Jul 31, 2009
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
The drum is not spinning and the machine stops and has LE on display
Sorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
I received code LE and washer stopped
HI!!
Good Luck!!
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 03, 2010 | LG WM-2277HW Front Load Washer
LE errorMashine get only a litle water and the motor make a noise and after this its coming a L E on the display
wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
Sep 10, 2010 | LG WM0642H
LG error code is 0E...what would be the problem
Washing machine has an LE error code --> Is this a new installation?
May 18, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Apr 13, 2010 | LG WM1814CW Front Load Washer
LE Problem
An LE Error Code is indicative of a ?Locked Motor? or ?Overload in the Motor?. This is rarely caused by a problem with the machine and in most instances resolvable over the phone. Q1:Are there suds in the drum? -->Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor. Follow the steps below to resolve an LE error code caused by oversudsing. --> Step 1: Unplug the unit and let machine sit for 30 minutes to allow suds to dissolve. Step 2: Press the POWER button to turn on the washer. Step 3: Press the SPIN SPEED button to select ?No Spin?. Step 4: Press the START/PAUSE button to begin drain only. Step 5: After cycle is complete, remove the items from the machine. Press POWER to turn on, RINSE&SPIN button, then START/PAUSE. Repeat, if necessary. This will remove excess suds and light residue from drum. Do this until no suds are seen in drum. Q2: Is this a new installation? -->In new installations, the code can appear simply due to a miscommunication between the control board and the motor. In this instance, the unit will simply need to be reset, much like rebooting a computer. Unplug unit, press and hold start/pause button for 5 seconds, plug unit in and test with a Rinse/Spin cycle. Q3:Is a large load size in a gentle wash cycle? -->Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle. Q4:Is the washer overloaded? -->Single bulky items (comforters) or extremely large loads can add extra weight to the drum which stresses the motor. Remove some clothing and restart. If it doesn?t work, unplug unit and let it sit for 30 minutes to allow motor to cool. Then restart the cycle.
Jun 09, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
