Question about Husqvarna Garden
I am looking for the crankshaft which used in husqvarna 3120xp engine. Can I buy it?
    President:
  • 2,559 Answers
Go here and view and order if you want or just use the part number to purchase locally
Posted on Jul 31, 2009
I need to replace an ignition coil for a 2006-7 Husqvarna snow thrower (10530SBE) 96195000102. What is the part number and where can I buy it?
The Snow thrower you have uses a Tecumseh LH385SA engine. The ignition coil you're looking for is part number 35135A and a few places online have it available. Below is one online location.
Tecumseh LH358SA Snow Blower Engine Ignition Module Coil 35135A FREE...
Nov 09, 2017 | Husqvarna Garden
I am looking to buy a used husqvarna mower 24hp 48cut turns over but wont start.do you think it will be a cheap fix or will i be wasting money.
it depends on the fault or problem it bears . I suggest to buy new instead of used , because it must be rusted and corrosion so it will continuously give you problems to repair and spending money .
Apr 07, 2016 | Husqvarna Garden
Hto remove crankshaft seals on a husqvarna 136 chainsaw
You will fully disassemble the engine as you must the cylinder from the crankcase. Husqvarna only sells the seals with the bearings they must be pressed on to the bearings. Since the 136 uses the same bearing set as the 141 you can order a set seals for the 141. In this the old seals must be pressed off first.
Here is a link to a site that sales the 141 seals.
Husqvarna oil seals set fits 36 136 141 142
Dec 21, 2014 | Husqvarna Garden
How to install a throttle cable model 3120xp
Instructions
1 Push the end of the new throttle cable onto the linkage on the carburetor, this is held in place with a clip, but on some other vehicles, the end of the throttle cable is capped and simply slides through a slot on the linkage.
2 Place the throttle cable clip over the linkage. You may need to pry the end up with a flat-head screwdriver to get it in place.
3 Secure the throttle cable in the throttle cable bracket located on the intake manifold. This, too, should clip into place.
4 Route the cable into the cab, being sure to keep it kink-free.
5 Loop the end onto the end of the accelerator pedal inside of the linkage hole. In other vehicles, there may be a clip on the accelerator pedal that holds the throttle cable in place, which is also easy to do with your bare hands.
Jun 24, 2014 | Husqvarna Garden
Flywheel for 1992 302 two big won't fit torque converter
Are you swapping engines? Only manual transmissions use a flywheel. Automatic equipped engines use a flex plate to mate the torque converter to the engine crankshaft. The flex plate is bolted to the crankshaft just like a flywheel, but is much smaller, thinner and with very little weight. If you do have a flex plate mounted, it must be the wrong one to match your torque converter and transmission.
Sep 23, 2013 | Bikemaster Motorcycle Magneto Flywheel...
Brake band 3120xp
This job os not to be taked on lightly, remove the hand guard by taking away the securing screw and pivots, be aware if you remove the roll pin without locking the spring and catch the locking lever can fly out under spring tention, i lock the top of the spring and catch, and the lower end of the spring in a vice ( this means the vice jaw is where the sprocket would sit, so be carful not to damage the cover ) then take the roll pin out, the top catch screws onto a thread on the band, be sure to count how many turns the catch is on the thread and re fit the same on the new band, it does not just bottom out
Feb 04, 2013 | Husqvarna 3120 XP Saw
Which ignition can I fit to my 3120xp 2012 Husqvarna that is unlimited?
I am running the ignition unit from the old Husqvarna 444 part no. 501681501 not sure if this is still available, its much easier to mod the K1260 ( power cutter ) this you can use the 372XP unit, it is possible to fit the unit from the 254XP but this involves drilling an extra hole in the units core, does your machine have two screws holding the unit or three? they may have started useing the crankcase from the power cutter on the later 3120. With a non governed unit you will hit a lot more than 12500, the carb has a fixed main jet, you may have to change this or open out the original
Nov 19, 2012 | Husqvarna Garden
Why does my husqvarna 3120xp pop while being ran wide open
The 3120 has an ignition govenor, so if you hold it at full revs free running it will pop, it is possible the govenor is coming in too early, this would mean replacing the ignition unit itself.
Apr 29, 2012 | Husqvarna Garden
Could you please tell me the fuel mixture for husqvarna chainsaw
All Husqvarna machines are built to run on Husqvarna oil at 50-1, with the exception of the 3120XP this machine runs a 25-1 mix due to its size, always try to use the manufacturer of the saws oil , wheather it be Husqvarna, Stihl, Poulon, all manufacturers produce there own oil, they know the lubrication requirements of there machines, so what i am saying is Husqvarna two stroke oil mixed at 50-1.
Feb 18, 2011 | Garden
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
